KZ1000 B3 Firing Order??
- manover21
09 Oct 2010 13:11 #405489
by manover21
KZ1000 B3 Firing Order?? was created by manover21
I'm reassembling my KZ1000 B3 LTD. What is the firing order and what are the plugs labeled sitting on the seat?? Does anyone have diagrams?? Thanks.
- TerryK
- Thank you received: 3
09 Oct 2010 13:48 - 09 Oct 2010 13:49 #405492
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic KZ1000 B3 Firing Order??
manover21 wrote:
Firing order: 1-2-4-3
cylinders are: left to right: 1-2-3-4
(If you Google KZ1000 firing order I'm sure you'll get an answer in about 4 seconds.)
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 09 Oct 2010 13:49 by TerryK.
- Thank you received: 2098
09 Oct 2010 16:04 #405509
by Patton
On KZ1000 B3 LTD, the pictured top coil is usually mounted on "shift lever" side of frame.
And pictured bottom coil is usually mounted on "foot brake" side of frame.
Replied by Patton on topic KZ1000 B3 Firing Order??
- PLUMMEN
- Thank you received: 104
09 Oct 2010 16:22 #405518
by PLUMMEN
Replied by PLUMMEN on topic KZ1000 B3 Firing Order??
dont tell trianglelaguna,but its the same on every 900-1000 ive ever seen from 73-80
- Thank you received: 2829
09 Oct 2010 16:24 #405519
by 650ed
Replied by 650ed on topic KZ1000 B3 Firing Order??
Are you trying to reassemble without a manual? :S
- Old Man Rock
- Thank you received: 225
09 Oct 2010 17:32 - 09 Oct 2010 17:32 #405539
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic KZ1000 B3 Firing Order??
Z1/KZ900/77/78KZ1000.... OEM Service Manual...
Pretty much all the same...
kzrider.com/index.php?option=com_docman&...d&gid=434&Itemid=108
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 09 Oct 2010 17:32 by Old Man Rock.
- manover21
13 Oct 2010 11:33 #406363
by manover21
Replied by manover21 on topic KZ1000 B3 Firing Order??
I have the original owners manual but it doesnt really help. Maybe I'm just stupid. I'm trying to get the rear cam to siut right now as he push rods are in the way.
