- Thank you received: 540
Heavy Duty Valve Springs Z1-KZ900 for stock cams
- z1kzonly
25 Sep 2010 20:24 #401848
by z1kzonly
Heavy Duty Valve Springs Z1-KZ900 for stock cams was created by z1kzonly
Before I assemble the head, can I use a set of used heavy duty valve springs on a stock Z1-KZ900 head with stock cams?
The springs are about an 1/8 taller than stock springs.
Marty
Marty
- PLUMMEN
- Thank you received: 104
25 Sep 2010 20:33 #401850
by PLUMMEN
Replied by PLUMMEN on topic Heavy Duty Valve Springs Z1-KZ900 for stock cams
what size are the springs and what did they come out of?
if they came out of a dragbike i probably wouldnt reccomend it
- Thank you received: 2829
25 Sep 2010 20:40 #401852
by 650ed
Replied by 650ed on topic Heavy Duty Valve Springs Z1-KZ900 for stock cams
Why, is there some performance gain you seek to achieve, or are they the only springs you have available? Ed
- z1kzonly
25 Sep 2010 21:43 #401860
by z1kzonly
Replied by z1kzonly on topic Heavy Duty Valve Springs Z1-KZ900 for stock cams
No performance gain.
Just preventing a bent valve, from a missed shift or over rev.
I have plenty of springs from old heads.
I bought these from "oikjohnson" from Ohio on ebay. $9.99.
They have a free lenght of 1.625 inch.
Stock springs measure out at 1.550 inch.
.075 inch taller.
Just thought it would give a nice crisp, tight sound.
And knowing at least they are better than old stock springs.
.075 inch taller.
- z1kzonly
25 Sep 2010 23:32 #401866
by z1kzonly
- otakar
26 Sep 2010 06:27 - 26 Sep 2010 06:28 #401890
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Heavy Duty Valve Springs Z1-KZ900 for stock cams
Do a compression load check on the springs. If they are too stiff, they can cause premature ware on the valves. I agree that your old springs should be replaced. Springs get tired with time. Stiffer springs will increase your potential redline. Put those springs on a spring load tester, compress them and see what the compression load is. I would never buy used springs unless I knew what the original specs of them was and how long they were installed and what they were used for.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Sep 2010 06:28 by otakar.
