- Thank you received: 3
racebike charging system
- 9am53
- homebrew, and some bbq
13 Aug 2010 07:43 #390590
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
racebike charging system was created by 9am53
I didn't want to hijack, so I just copied the image. I have seen many racebike pics thanks to kzz1p, and many of them have the alternator seemingly removed for weight savings/turning clearance reasons. How does the charging system work on these bikes? Is there a belt for a magneto somewhere that I am missing? I would think that a battery would weight more than a stator and some magnets...
thanks for the noob Q&A!
'84 GPz900r
'71 CB350
- trianglelaguna
- Thank you received: 235
13 Aug 2010 09:26 #390640
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic racebike charging system
some have a battery just to provide the twelve volts to the coils and some have a little magneto on the alternator/stator side ...the one in the picture had a kx80 dirt bike magneto to provide juice to the coils in a total loss igntion system....
this is a butchered version of what i have found ...
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
13 Aug 2010 09:33 #390643
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
the battery losses charge but lasts 20-30 laps???
1976 KZ900
2003 ZX12R
2007 FZ1000
- JakeB
13 Aug 2010 10:05 #390646
by JakeB
1978 Z1-R
Replied by JakeB on topic racebike charging system
With regard to the weight difference, you can't just compare the static weight of the charging system and battery.
The rotational mass of the rotor has much higher performance consequences than it's simple static weight. Removing the rotor reduces the mass of the crankshaft significantly making the engine rev quicker.
Another factor which has only a small effect is that the stator applies an opposite force to the rotor (to make electrical power) which consumes some of the engines power that could otherwise be used to make the bike go faster.
Plus, like you said, it does free up some ground clearance on the left.
Keep in mind, this is mostly just speculation by me based on recent physics courses.
1978 Z1-R
- Jack
- Thank you received: 7
13 Aug 2010 10:32 #390650
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic racebike charging system
You got it, removing the reciprocating weight is free horsepower. Dragbikes get a charge between rounds to keep up the volts that MSD or Dyna need. Lots of folks are going to lightweight hi power lithium batteries that will make 2-3 passes without requiring a charge.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- 9am53
13 Aug 2010 20:12 #390763
by 9am53
'84 GPz900r
'71 CB350
Replied by 9am53 on topic racebike charging system
so Jack, a lightweight battery is the way to go then?? A little magneto sounded interesting
'84 GPz900r
'71 CB350
