Wrong Oil Filter Bolt?
- Kyle_w11
1976 KZ 900 A4 with 1974 Z1 Big Bore Engine - 10,000 mi.
- Thank you received: 2098
With nothing but the bolt itself being screwed in, what apparently stops it when it won't screw in any further.
For example, does it run out of thread?
Or does it bottom out with exposed thread still remaining?
- Thank you received: 2829
KZ900 doesn't have the fence.
Sorry, my mistake. I guess after 33 years of changing the oil on my KZ650 I assumed everything from a Whizzer scooter to a B1 bomber uses the same oil filter configuration as the KZ650. :laugh:
- Motor Head
- Thank you received: 391
- Gman
- Thank you received: 5
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
- Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- Kyle_w11
- Kyle_w11
That is the wrong bolt. Note the location of the O-ring. The bolt should measure 115mm from the head flange to the end of the bolt. Sorry the numbers aren't visible in the pic.
The new one they gave me turns out to be 110 mm but does have the right o-ring location.. There are also 14 holes in the damn thing, and it has a Ball/Spring/Pin assembly inside as well.. It measures 19 mm threads.. not sure what pitch though
- Kyle_w11
I run out of thread..
Can anyone tell me what the thread specs are for this bolt?
...Can anyone tell me what the thread specs are for this bolt?
Sorry I don't know the thread specs. Can't measure just now 'cause mine are busy.
Is cutting additional thread being considered?
Meanwhile, here are some ebay items.
- Kyle_w11
