Wrong Oil Filter Bolt?
- Kyle_w11
09 Aug 2010 18:35 - 10 Aug 2010 15:20 #389740
by Kyle_w11
1976 KZ 900 A4 with 1974 Z1 Big Bore Engine - 10,000 mi.
Wrong Oil Filter Bolt? was created by Kyle_w11
Are all KZ 900 oil filter bolts the same? I have a '74 KZ 900 engine and the previous owner didnt have an oil filter assembly.. i've tracked one down and go to put it in.. the bolt doesn't go in far enough to seat the oil filter cover. Are there variations of filter bolts?
Last edit: 10 Aug 2010 15:20 by Kyle_w11.
- PLUMMEN
- Thank you received: 104
09 Aug 2010 18:43 #389745
by PLUMMEN
Replied by PLUMMEN on topic Filter Bolts
i wouldve guessed theyre the same,did you check the threads?
- Kyle_w11
09 Aug 2010 18:51 #389747
by Kyle_w11
Replied by Kyle_w11 on topic Filter Bolts
yes, it goes pretty much all the way in with my hand.. I go to torque it to 65 in-lbs and the cover isn't even seated.
- Kyle_w11
09 Aug 2010 19:02 #389755
by Kyle_w11
Does anyone have one they can measure? with the oil filter bolt in hand and the oil filter cover on the bolt. i measure 97.87 mm from the end of the bolt to the mating face of the oil filter cover.
- Kyle_w11
09 Aug 2010 19:16 #389762
by Kyle_w11
i'm thinking the guy at the shop gave me the wrong bolt. here's a pic.. looking at the holes, they're slotted and chamfered.. it looks like it might be the wrong one.
Here is the measurement I was taking
Here is a pic of the oil pan.. doesn't look stock to me.. any input..
- KZ250LTD
- Thank you received: 16
09 Aug 2010 21:18 #389785
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic Filter Bolts
Nope, doesn't look like the stock one. if I'm right, its a deep sump pan that someone has either modded or bought from someone. Doesn't look particularly professional though...
79 KZ1000ST
Past:
Many.
- Kyle_w11
10 Aug 2010 07:10 #389866
by Kyle_w11
That just means the sump is modified though right.. the oil filter assembly should be the same, no?
- Kyle_w11
10 Aug 2010 09:45 #389894
by Kyle_w11
From what I understand this bike was modified for a friend in the early 80's from a guy who raced/built drag bikes. Clearly he didn't completely finish the buid. I guess he just got the engine built and back into the bike and that was it. It baffles me that the oil filter assembly is missing though. I agree it doesn't look professional but it will do the trick. What's the purpose of the deep sump? is it just more cooling time?
- Thank you received: 2829
10 Aug 2010 10:17 #389899
by 650ed
Replied by 650ed on topic Filter Bolts
You do have the rest of the oil filter assembly parts (fence, spring, washer) right? ed
- Kyle_w11
10 Aug 2010 12:44 - 10 Aug 2010 12:52 #389916
by Kyle_w11
I have the Bolt, Cap, Spring, washer and filter. complete with o-rings. By fence I assume you mean filter..
Last edit: 10 Aug 2010 12:52 by Kyle_w11.
- MFolks
- Thank you received: 540
10 Aug 2010 12:53 #389919
by MFolks
Replied by MFolks on topic Filter Bolts
I believe it's a shield that covers the top of the filter assembly. It goes about 1/4 down and looks like SS.
- hocbj23
- Visitor
10 Aug 2010 13:28 #389924
by hocbj23
Replied by hocbj23 on topic Filter Bolts
Deep sumps have two purposes,one to allow more oil in the crankcase as more oil =better cooling and more lube.Second reason is to retain some oil where needed for extremes in accel or decel where all the oil tends to run from one end of crankcase to the other,thus causing either oil pressure lite to come on or oil pump pickup to run dry.I have a Schnitz Racing oil gate in my bike for the same reason.bj
