- Thank you received: 3
Braking
- TerryK
So, my question to you fellow riders, is what is the percentage of front to rear brake application you normally use?
Myself its about 90% front, 10% rear in most situations.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- Kidkawie
- I bleed premix
- Thank you received: 245
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- asevans
1976 kz900 Mostly stock
1978 Z1-R Project
- OnkelB
- Thank you received: 80
In slow (below 25 mph) city traffic I tend to use the rear the most. Approaching a turn braking down from speed I'll usually use both, applying a bit of rear before hitting the front - once leaned over and needing to slow down even more I'll apply the rear gently, if you ever had the front end wash out under you you'll know why....
Most of the time it's a combination of both - I like to apply a bit of rear brake before hitting the front brake, as already mentioned a bit of rear brake will stabilize the rear end before braking hard with the front. I used to use the front brake almost exclusively, but I changed my ways.
Another variable is surface conditions - on gravel roads, wet surfaces or grass I never touch the front brake alone, learned that the hard way.
77 KZ 650 B1, 82 GPz 1100 B2.
- hocbj23
- Visitor
- mjg15
75% rear,25% front.bj
You must be fully paid-up at the karma bank.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
- Thank you received: 2098
Where feasible, I am trying to use the rear brake a little more as a helper in "normal" slowing and stopping situations. In hopes that it will minimize front tire cupping.
Am recalling that this info tidbit came from Dunlop Tire Co.
But so long as front brakes are relatively perfect, and not pulsing, maybe it doesn't make much difference as to tire cupping.
- porchev914
- Thank you received: 19
FRANKEN Z!
- hocbj23
- Visitor
Yeah, and Im fully paid up at the blood bank too.Lol. Been riding since 1954,always laid off front brakes as road conditions in SETN were not always that great-lots of loose gravel,etc.Learned early on the gears plus the rear brake were more dependable in hard stops than were the fronts.Works for me-have yet to lay one down on a hard brake or panic stop.I do use the fronts some for slow downs in the twisties,and traffic in town but that is for convenience.Everybody has their riding style and thats just mine.I may have to modify some in the future as I have 2 bad knees now so the fronts are going to have to take up some slack due to lack of leg mobility.bj
