- Thank you received: 1
bad fuel
- ace
- 78kz1000
- otakar
25 Jul 2010 05:41 #385477
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic bad fuel
Ethanol will make the bike run lean.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Old Man Rock
- Thank you received: 225
25 Jul 2010 06:23 #385487
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic bad fuel
Running poor which way?
Reason I ask...
Here in Az Oct/Nov through winter months, corn entho here at gas pumps but it's cooler weather so the old girl runs fine...
AZ summer heat, she still performs but not like when in cooler weather with same gas even....
Anyhoot... what is happening?
Or was it just bad gas (low quality) from that station vs the entho concept....
Reason I ask...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- ace
- 78kz1000
25 Jul 2010 10:01 #385544
by ace
78kz1000
Replied by ace on topic bad fuel
seems to lack the punch she once had (78 kz1000a) also takes a long time...5 mins.. to warm up and hold idle at 1000 rpm. ive added inline fuel filters just to be safe. i always ran the cheap gas b4 with no problems for years,now i run premium. is this normal for my baby ????
78kz1000
- KZ250LTD
- Thank you received: 16
25 Jul 2010 11:24 #385556
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic bad fuel
iirc there was a thread here awhile ago about ethanol degrading regular fuel lines. I would assume it could do the same to rubber carb parts, etc. I just run reg and she rips!
79 KZ1000ST
Past:
Many.
- kawsakiman
- Thank you received: 6
25 Jul 2010 14:18 #385600
by kawsakiman
Replied by kawsakiman on topic bad fuel
Old Man Rock wrote:
Here in Az Oct/Nov through winter months, [/quote]
winter months in az? :blink:
what is that? temp only goes up to 70 ?
- KZQ
- Administrator
- Thank you received: 1413
25 Jul 2010 17:54 - 25 Jul 2010 17:54 #385745
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic bad fuel
I've noticed that today's politically correct gasoline is prone to plugging jets in as little as two months. I just recently learned that the powers what be know all about it, I mean take KZR as an example, change the BAC from Zero to 10% and so many corpuscles get blocked that you can't see anything but spitting shims!!!!! That's just an aside the simple truth is that alcoholic gasoline may run fine for a while, particularly if you're gonna run it daily but winter storage will require nonalcoholic fuel.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 25 Jul 2010 17:54 by KZQ.
- Old Man Rock
26 Jul 2010 06:06 - 26 Jul 2010 06:09 #385860
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
"winter months in az?
what is that? temp only goes up to 70 ?".....
:laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
Well bring your KZ in August big guy... :laugh: You feel you have to shift down to 4th to pass now, yeah bring out here.... :evil: :whistle: :laugh:
Back to subject matter....
"i always ran the cheap gas b4 with no problems for years,now i run premium. "
This may be the cause... Otto just posted an interesting posting on Octane differences regarding power performances.... Next tank fill, go back to what you where previously running regarding Octane....
Please post the results....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 26 Jul 2010 06:09 by Old Man Rock.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
26 Jul 2010 06:27 #385866
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic bad fuel
You may just need a good tune-up
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
26 Jul 2010 07:15 - 26 Jul 2010 07:17 #385880
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Here in Chicago we have no choice. Our gas is 10% Ethanol from May to September and 15% Ethanol the rest of the year. You just have to jet accordingly and use additives to prevent corrosion inside the carburetors because Ethanol is very corrosive. These bikes when they came out void the warranty if you used "gasohol" which is what they called gas that had 10% alcohol in it back than. Also these bikes have a tendency to build up crud on top of the pistons and inside the combustion chamber. This is why premium gas will perform better in older bikes due to their increased compression. The muck inside the chambers can be cleaned out by using "Combustion chamber cleaner" This will put your compression back to original and the bike will run better on regular gas. You will find that if you run Lucas Fuel additive that this will stabilize the ethanol rich gas and will also make the engine run better in relatively short period of time. Yamaha also sells a similar product (much more expensive) which they recommend regular use of.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Jul 2010 07:17 by otakar.
- otakar
26 Jul 2010 07:21 - 26 Jul 2010 07:24 #385881
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I never run a single tank of gas in ANY of my vehicles with out running Lucas. You can buy it in 5oz., 32oz., and one gal. bottles at any good auto parts store. I add 1.25oz for every tank of gas on the bike. (2.5oz/10gal gas)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Jul 2010 07:24 by otakar.
