- Thank you received: 10
ITS TOO POWERFULL!!
- Kitten Tooth
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- bill_wilcox100
- Thank you received: 5
Check the voltage at the coil inputs. They must be almost the identical voltage as the battery. If not you have losses in your wiring connections and or switches. Be prepared to repair or replace your switch gear or to implement the Coil Re-powering Mod. See diagram of how I implemented this on my bike:
For more details see Link .
Be warned that not all members subscribe to this Coil Mod approach preferring instead to find the one or more contact issues and then repairing or replacing them. But for about $10.00 USD in parts it’s hard to beat. All I can tell you is that many, many of these bikes, including mine have been saved and are still on the road because of this mod... and it's a simple way to rule out carb issues and get on the road now.
Best of success,
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
- Old Man Rock
- Thank you received: 225
Only having the coils at ideal voltages while the rest of your electrical system is being held under, this may lead into other problems down the road such as burnt up components i.e. Dynamo/rectifier/regulator....
As for carbon build up, depends on the degree of carbon build up your speaking of.... You will want a lite 360 carbon build around the plug base ring... Don't worry about obtaining a tan colored insulator for the gas in your area may just never allow this to happen... Mine aren't as well...
Here's a good guide Cavanaugh turned me onto for Spark Plug reading.... Worth reading/studying...
kzrider.com/index.php?option=com_docman&...d&gid=460&Itemid=108
Also insure once fully carb tuned and sync, cam timing and ignition timing are spot on... I can't remember if you installed Dyna EI or have points/condenser in your KZ.... Either way, dial her in....
Another thing to accomplish, take some Emory cloth and clean all the electrical panel plug pins of oxidation... Do this on all your harness connector pins as well... You'll be surprised on how much this effects your coil voltage...
Just in case... sorry if re-posting the electrical tests...
KZ900 test pretty much the same for early 1000's...
Good luck young man, keep at it!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Make darn sure that the connections from the stator/alternator to the rectifier/regulator are perfect.
Also make sure that the ground wire from the rect/reg unit has a real good ground (maybe make a secondary one, and that the battery ground is connected directly to the engine, and the frame in different locations.
This helps ALOT to prevent wiring shorts and charging circuit issues that can leave you stranded.
Going through the wiring on the bike and cleaning and re-connecting everything only takes a few hrs, and can make a world of difference and sweet peace of mind.
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
- Thank you received: 104
youre learning,it took me numerous backflips and a few trips to the e.r to learn to be scared! :laugh:okay, i got an airfilter a week or so ago and i have been going on small rides with my dad.. the past few days have been great. Im kind of scared of the thing, this is the first bike i have owned that doesn't just have the ability to do wheelies but WANTS to do them:D i of course do not.. Im going to tune my carbs on saturday after buying a valve for my supplementary gas tank that will hang above my bike as i do the tuning. I posted a thread before about my exhaust popping when i downshifted. You guys said it was a sign of a lean mixture. I ran the bike for a few hours and pulled the plugs when i got home. They were black like it was running rich.. nothing new with that until saturday when i do the tuning. Also, my valves seem to be ticking like the motor is low on oil.. its not but it sounds like it. Any ideas? might now go full drag bike but i will get an extended swing arm and 4 into 1. I'll keep you guys posted..
Thanks guys,
KT
have you checked your valve clearances?carbs being out of synch will cause cam chain noise at lower rpms also,especially idling
