If it doesnt start, should i sell it???
- RobQ
- Thank you received: 2229
The bike may start and run just fine when you get the carbs back on, but that is a long shot. There are likely other problems that need attention, but your novice status may prevent you from identifying them right away. If you are willing to spend the time and money to learn how the bike is supposed to work and how to fix it when it does not, then this relationship may work out. Otherwise a new small displacement bike might be a better fit for you. If there is a shop or dealership nearby that you trust, you might get a pretty good deal on a barely used one and the money you save can go toward getting the KZ operational again. It basically boils down to your disposition, finances and goals.
- RobQ
- RobQ
Shweet. Now i have 2 problems after sucessfully starting the bike. 1, after starting it sounds like i am giving it full blast accelerator. BUTT!! i did have the exaust off and i forgot to turn the choke back to the closed position after starting so that could very well be my problem. So ill go with that for now. My other problem which was the original problem when i received the bike is once started, carb 1 leaks out of the drain. 2,3,and 4 do not leak but num 1 still does and its a fairly fast drip. The carbs are beyond clean. Maybe just the drain plug screw is bad or the o ring in that screw is bad???????
- KZ250LTD
- Thank you received: 16
79 KZ1000ST
Past:
Many.
- Thank you received: 2829
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- Thank you received: 2098
...problem which was the original problem when i received the bike is once started, carb 1 leaks out of the drain. 2,3,and 4 do not leak but num 1 still does and its a fairly fast drip. The carbs are beyond clean. Maybe just the drain plug screw is bad or the o ring in that screw is bad???????
Might be cracked overflow tube.
- cobura
- forever 2 wheels
- Thank you received: 3
1979 KZ650B3
- ready2ryde1985
- got to love these kzs
- Thank you received: 4
The other + is that not just anyone rides these bikes they take time pacience and an understanding g/f lol
Just sayn you will look alot cooler on a hand built bike that isnt perfict compared to a cookie cutter pretty bike lol.
84 kz 700 a1
82 kz550 ltd
- schmol
