Which Biike Do I Have
- The Wolf
- Alone is cool ...But Packs are better
11 Jul 2010 12:07 #381684
by The Wolf
[img][/img]The Wolf
Which Biike Do I Have was created by The Wolf
Hello all,
I know this sounds wierd but I am just not sure.
The Vin Num is KZ400H-004217 it says it is a 1979 on the title,on the side of the bike it has a side cover that has 440 LTD on it.
I need to know so I can start working on it with the right parts.
Thank You
Larry
Thank You
Larry
[img][/img]The Wolf
- Mcdroid
- Gone Kwackers
- Thank you received: 316
11 Jul 2010 12:31 #381691
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Which Biike Do I Have
Your motor might not be original to the frame...please post the motor VIN also.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TerryK
11 Jul 2010 14:26 - 11 Jul 2010 14:27 #381719
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Which Biike Do I Have
It's obviously a KZ400 with LTD side covers on it.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 11 Jul 2010 14:27 by TerryK.
- The Wolf
13 Jul 2010 10:27 #382268
by The Wolf
[img][/img]The Wolf
Replied by The Wolf on topic Which Biike Do I Have
Hi There Again,
Well here is the engine num also....K4E121004
Thanks for allthe help
[img][/img]The Wolf
