- Thank you received: 104
I'M TOO SHORT FOR MY BIKE...PLEASE HELP ME !!!
- larrycavan
- Visitor
larrycavan wrote:
picked that suit up last time i was in pencil-vania looking for a good engine builder,all the locals were wearing them! got the boots off the rack at jcpennys clearance aisle! :woohoo:You might ask Jim where he got his riding boots. I belive they're called Nebraska Nikes
We had a convention last summer...obviously we had our shorts suits on.... :laugh:
- PLUMMEN
- JMKZHI
- Thank you received: 48
As for the front, you might be able to install a spacer or spacers in the lower portion of the forks around the rebound spring. If you can, doing so will reduce the amount of fork travel & will apply more preload to the upper springs.
Also, look at the forks where they are fitted into the upper triple to see if you can raise them some by loosening the triple clamp bolts then sliding the fork tubes up. If you can, do so with an engine block or support under the bike so that it doesn't fall down. You might be able to get an inch or so - maybe a half inch.
PS: you didn't say what particular Police bike it is. And you should lower the front about the same amount as the rear. Also, be aware that lowering it may lead to clearance issues while riding, such as at the rear tire mentioned above.
- Jack
- Thank you received: 7
At the risk of shameless self promotion, I just listed them in the classifieds on here today.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Capt America
- Born Bad
Note: if you're a stock fanatic look away now!
If you plan to keep this as your permanent ride, you can just have a good welder cut out both rails indicated by the arrows and have him weld them back in lower in the frame.
OR
I found that cutting only at the back arrow marks and applying some heat to the front arrows (like 2 inches back of the welds to the cradle) to just bend them down a bit and re-welding the rear arrow marks lower can easily give you as many inches as you desire. If your welder is good, and does one side at a time ( cut, bend, tack) ( cut, bend, tack) you don't even need to worry about a frame jig.
You'll have to go with a different seat, maybe a Harley dyna one, etc. You do have to rework your battery box a bit to keep it level and rework mounts for other electrical stuff, and say goodbye to your side covers.
I don't recommend this if you intend to sell the bike in the future.. but it's a good fix for short legs if it's going to be your ride for many years to come. It also allows you to keep the bikes suspension as it was intended.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- KawiConvert
Old Man Rock wrote:
16" tires tend tohave taller profile compared to 18"Huh.... How can it be that with a 16/17" rim versus 18" rim your center axle point is not dropping.... Ok, what am I missing here.... :S
Christian... pant inseam?
Reason I ask, I have a 32" inseam... Corbin seat and using 17" rims/tire sizes... I can plant both feet firmly (flat) and comfortably on the ground while sitting on the seat....
Anyhoot, smaller rim/tire sizing, shorter shocks, seat fabbed mounting etc... and you should be able to get a somewhat safe configuration....
Edited Miss-type: Thanks Patton....
You may still drop up to 0.5" depending on the tire. Thats about the difference between the 18 and 16" wheels with tire for the 650.
Yamaha XS 1100 special rear shocks are shorter. I'll see if I still have a pair if you are interested.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
