Finding diagrams and parts info on kawasaki.com
  • Patton's Avatar Topic Author
Re: Finding diagrams and parts info on kawasaki.com
19 Jun 2010 08:08
#376776
Mcdroid wrote:
...caveats I'd add...are (1) that a few models appear to be not available on the Kawasaki site. For example, you ultimately get an error message when searching for Z1A and Z1B models. On the model line, you must insert a '-' between the Z1 and A or the Z1 and B. The model name will initially look like this: 'Z1B' and you should change it to look like this: 'Z1-B'. Click the green arrow to the right and then you will get the exploded diagrams....
Works like a charm! :cheer:
  • CrazyHarry
  • CrazyHarry's Avatar
22 Jun 2010 04:55
#377495
Similar site in Europe is www.cmsnl.com/
Has parts diagrams for all the big 4 Japanese makes.
re. Kawasaki.com... try:-
www.kawasakiepc.com/SystemSearch_Frames.cfm
Gives you the full range of search options.
24 Jul 2010 20:21
#385431
Would like to confirm that the US and CA and CN in the part numbers columns refer to USA California and Canada.
Thanks. :)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
24 Jul 2010 21:56
#385447
The first site is nice...gives us some options for Euro models...could not get the second site to work.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
24 Jul 2010 22:00
#385448
Thanks. :)
Noted. Thanks. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: Sactown900
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
13 Oct 2010 06:16 - 13 Oct 2010 06:16
#406313
Nice job Patton! This should be a Sticky.
I did a similar post on a dirtbike forum which helps out bigtime since dirt riders are constantly swapping parts.
One thing I would like to add:
Alot, not all, Kawasaki parts have the last 4 digits of the part number on the actual part. These last four digits is what seperates a particular part from another in regards to the "Reference Number". Basically, a reference number ONLY references the part in the diagram and there may be 100 different parts with the same reference number but different last 4 digits of the part number.
Example:
A cylinder for a 2 stroke engine reference number is 11005. so that's the first part of the part number. Kawasaki pretty much changed porting on their cylinders annually and each one got a new part number. One of my cylinders has "1851" stamped on the side. So I take the reference number and add the last 4: 11005-1851 and I can tell now I have a 1998 KX250 cylinder. There may be 20 cylinders that look the same but those 4 digits is what defines them. If you look around your bike you'll start to see all the part numbers.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 13 Oct 2010 06:16 by Kidkawie.
17 Nov 2010 11:32
#413175
Selecting the desired individual diagram normally results in a split screen with exploded view on top and parts listing at bottom.
In event the screen isn't split, such as showing only the exploded view but no parts listing, it may be possible to drag the "split-line" upward, and adjust to viewing preference.
Good Fortune! :)
[Click on image to enlarge view.]
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
17 Nov 2010 12:21
#413180
One of the colossal benefits to looking up parts on Mother Kawasaki's site was that you could determine if a part was still available from a Kawasaki dealership (or in my case, Z1Enterprises). As it turns out, I was looking for a rear signal bracket for a KZ1100-B2 and the Kawasaki site showed the part as still available (still does BTW) ...steep, but still available. Great! Ordered it from Jeff and was told shortly later that the part was NLA. So, just because it is noted as 'active' on Kawasaki...it isn't necessarily so. Alas.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
17 Nov 2010 12:43
#413181
No eBay APP ID and/or Cert ID defined in Kunena configurationMcdroid wrote:
...looking for a rear signal bracket for a KZ1100-B2...NLA....
:unsure: Is this it? :unsure:
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
17 Nov 2010 15:44
#413199
No...23062-1032 is what I was looking for.
Michael
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
30 Sep 2014 13:40
#649225
Well, thought I'd reawaken this thread. Looks like MaKawi has slipped us a mickey... They changed their part diagram site and only go back to 1984 now. See Eds post: kzrider.com/forum/13-bike-related/595986...diagrams-gone#649219
We can only hope that enough voices get them to provide that info again.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
The following user(s) said Thank You: pete greek1
  • JoeK
  • JoeK's Avatar
02 Oct 2014 22:10
#649483
As I stated in the other post, I actually work on the Kawasaki Website. I can't speak for Kawasaki, but it's my belief that we are doing everything in our power to provide all the parts diagrams for pre 1984 products as they were on the previous site.
As an owner of a 1977 KZ1000, I totally understand your concerns. Please be patient as this new site was a major undertaking. I can assure you that Kawasaki Corporate has received many complaints about the missing parts diagrams.
I'm not telling you to quit asking, just asking the community to be patient. Thank you for being loyal Kawasaki customers.
1977 KZ1000 - coolest
1973 Honda CB-750 - oldest
2004 Yamaha FZ1 - fastest
www.jekgraphics.com/gallery/kzr Galleries of So Cal Events
www.VintageBikeOC.com Monthly Meet of Vintage Bikes in Orange County, CA
The following user(s) said Thank You: Mcdroid, bluej58, peter1958, !Seymore, Space Truckin
