- Thank you received: 19
Yoshiumira KZ Exhaust: Measurements anyone????
- hocbj23
- Visitor
30 May 2010 19:30 #372202
by hocbj23
Replied by hocbj23 on topic Yoshiumira KZ Exhaust: Measurements anyone????
cool.no disrespect of anyones expertise intended.bj
- porchev914
30 May 2010 20:48 #372218
by porchev914
FRANKEN Z!
Replied by porchev914 on topic Yoshiumira KZ Exhaust: Measurements anyone????
Of course not, I understood you were only stating the caution needed, I was just trying not to hijack OMR's thread
FRANKEN Z!
- Old Man Rock
- Thank you received: 225
31 May 2010 08:04 - 31 May 2010 08:23 #372271
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Yoshiumira KZ Exhaust: Measurements anyone????
Don't sweat it guys for you're not hijacking, we're cool...
Yup, have spoken with Larry numerous times on what we're trying to accomplish regarding the tuning (steering) of the power band... Different concepts were discussed regarding air flow & obstructions where Larry replied that in a properly tuned engine/head this air flow at the exhaust ports is really strong so don't get to wound up about it...
What can I say, when the man speaks I listen...
This pipe will be going on my stock KZ 1000 when finished... The head will be a Larry rebuild with mild P&P but stock cams for the initial install.
This bike will be used mostly for the wife's and I cruiser.. Plan is to steer the power band mid range ~ 4K-5K for cruise and passing umphka... I'll be sticking with stock sprocket gearing as well...
Obviously, WOT is not required in this KZ... Wife would get poopy-skivies... :laugh:
Edit: Somewhere like this....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 31 May 2010 08:23 by Old Man Rock.
- hocbj23
- Visitor
31 May 2010 12:16 #372341
by hocbj23
Whoa.nothing like a nice ride on a hot day with poopy skivvies.aLL i CAN SAY IS MUCH GOOD LUCK ON THE PROJECT.iF U GET A SET THAT WORKS AT MID-RANGE,i AM SURE LOTS OF FOLKS ON HERE INCLUDING ME,WOULD ALSO WANT A SET.Aw pooh,excuse the caps lock.anyway,good luck.bj
- Old Man Rock
31 May 2010 13:07 #372357
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Now that the KZ900 is 100% completed (oil cooler last thing to accomplish) other than normal maintenance...
I'm now ready to dive into the KZ1000....
Already started the pvc template bends so should have a mock PVC exhaust shortly.... I'll keep you posted with images as I go....
Most likely will start a new project posting on the exhaust build...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- porchev914
17 Oct 2010 22:21 #407344
by porchev914
FRANKEN Z!
Oooooooh, I cam across a thread on sand bending exhaust tubing on this site
www.jalopyjournal.com/forum/showthread.php?t=293162
One of the members tried some different dia/wall thickness tubes using sand and a torch. The Ti tubing turned out niiiiiiice
Just a little something to think about OMR while working on your prototype.....Unless you already read that sites thread. Then just regard this as a bump to find out what you've been up to :woohoo:
FRANKEN Z!
- Old Man Rock
18 Oct 2010 05:40 #407380
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Thanks for the link.....
I'll be starting with mild steel first, cheaper on the "OH Shit" factoring.... Plus I have a tig rig w/regulator but not a 220Vac welder (reverse polaritiy) or Argon bottle...
MS and MIG welder will be just fine for now....
Stainless you have to be careful with in not using too much heat or you turn it into carbon steel.... If a magnet sticks to it, too bad you screwed up....
I would think TI follows the same rules as most alloys regarding heat but I truly haven't looked into TI to that extent due to costs.....
There's some cool sites out there on tube bending and exhaust tuning design applications.... The search is still on but I'm a ways until I reach hands on... Other things to do first...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
- Thank you received: 235
20 Oct 2010 12:09 #407775
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Yoshiumira KZ Exhaust: Measurements anyone????
not a yosh but still a pretty cool link i found
www.moriwaki.co.jp/product/pdf/exhaust/01810-D3213-00.pdf
1976 KZ900
2003 ZX12R
2007 FZ1000
The following user(s) said Thank You: west coast kz
