- Thank you received: 225
Yoshiumira KZ Exhaust: Measurements anyone????
- Old Man Rock
That's the beauty of designing your own "TUNED" exhaust... Designed and built for where your steering the maximum power band rpm range your desiring.
Example, pending your engine build... As in my case, the cam selections I chose are designed for low to mid range power... Sure, they operate as well as WOT but the mid range is where she truly pulls you off the bike... :woohoo:
With that said, the design of the exhaust should also compliment the build where the power band is mid range as well... 3k - 5Krpm (50 - 70mph)...
Here's a couple examples of some calculators I have found... There is a science to this after all....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- trianglelaguna
- Thank you received: 235
this guy has one someone made....honda ---but same concept...it retains the flow ok imo....a little thick on the metals and a tad under the quality and finess from what i can see...but better than many attempts i bet...not bad really......maybe he knows some background on who learned enough to make this pipe...contact him for info and see...maybe the welder/fabber...has made kz's too...
might share his notes.. lessons learned...mistakes...suppliers ect.....cheers
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Old Man Rock
If this is the same guy we've seen before, he only does Honda Yosh reproductions, no KZ's...
Still cool as hell if you ask me... But hey, what do I know.... :laugh:
Thanks Craiggy...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- porchev914
- Thank you received: 19
Like I said before, start out with an existing header and bend your own tail pipe.
That would certainly be easier, no argument there, but where's the fun in that? That's just like telling someone to buy a bike instead of building it. Sure it's difficult, time consuming and takes a myriad of skills, some of which you may not possess. But that's what makes it fun! (To me anyway) challenging yourself to learn something new or do something different. That's what I would get out of it anyway
FRANKEN Z!
- porchev914
FRANKEN Z!
- Old Man Rock
I had been eye balling their roller as well.... One thing got me thinking about the curved design though is front tire heat... Still debating it...
But I sure luv the way it looks...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- porchev914
I set it under the Series II Yosh header I have so you can better visualize how far the constant radius curve sticks out past the Yosh primary tubes.
FRANKEN Z!
- porchev914
There is so much room to play with things though- instead of the single tighter radius I put in after the exhaust port, you could put a longer, larger radius in, then flaten out the main constant curve in the primary, then tightening up the radius a bit into the collector. The options are infinate
FRANKEN Z!
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- hocbj23
- Visitor
- porchev914
FRANKEN Z!
