- Thank you received: 7
Yoshiumira KZ Exhaust: Measurements anyone????
- austin3119
- porchev914
- Thank you received: 19
FRANKEN Z!
- porchev914
FRANKEN Z!
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Old Man Rock
- Thank you received: 225
The curved risers will be similar in concept... Right now, just doing the bends in 1.5" PVC piping... I'll use these individual bends as a template in mild steel.
The 4-1 collectors are way expensive even for carbon/mild steel... Been researching and designing to the best way to fab my own....
To make things easier, go 2-1 on each side of the swingarm but that would be the easy way out...
Again, not in any rush so really just playing with it for the time being. I'll keep you all posted when I get hot & heavy into it with images of course...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- porchev914
I may give this a shot as well...... in a few months. I'm going to need a header anyway. Besides, I'm famous for spending 3X's the money to build something I could have bought :laugh:
I wonder if making the 2:1 collector would be easier with a solid die and a press to stamp it out in two halves, then weld it together......?
FRANKEN Z!
- porchev914
I havent had the baffle out of my yosh since I bought it. I probably should re-pack it though, she's not in the least rough shape. i may see how it sounds as is first though. If you start making pipes OMR you might become very popular around here.
You bastards with your fancy exhausts, whining about packing them! :laugh: No concern for those of us without any exhaust :whistle:
FRANKEN Z!
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- Thank you received: 2098
[Click on image to watch OMR at work.]
- Old Man Rock
example... Put too much heat to stainless and it becomes carbon steel... We use to run into this all the time in welding... Inspectors walk by with a magnet, it sticks, you're screwed... cut it out and start all over...
So the only way I can see truly bending that would be in a Mandrel system, no other true way to accomplish ideally. Ok, unless you want a whole slew of angled and welded pieces... Blah, not worth it at the point...
And to be able to pull it off... I mean seriously, look at the beauty of this rounded riser... Sweetness...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- cobura
- forever 2 wheels
- Thank you received: 3
Here is a link to the most common place to find bike parts in japan:
list1.auctions.yahoo.co.jp/jp/パーツ-.../26312-category.html
you can search for yoshimura by entering: ヨシムラ
you can search for moriwaki by entering: モリワã‚
You may not be able to read the texts i wrote above if your computer cant handle japanese.
1979 KZ650B3
- Old Man Rock
Well can;t say but what was claimed...
Here's some 70's era ;literature of a rounded riser design... luv it....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
