- Thank you received: 10
82 KZ 750 Vs. 01 ZX-6R
- timebomb33
I THINK MY POWERBAND BROKE
- WPBill
- Thank you received: 12
simple.
just pull one or two plug wires off her bike.
That's a bit too visible. I'd mess with spark plug gapping. Or better yet pull one of the wires, bend/twist it violently to cause a break in the conducting material, confirm work with ohm meter, then re-install.
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
crank work
new rods +1mm on the small end
low comppression 810 kit
valve train bits
cylinder studs and nuts
then give these guys a call
www.mrturbo.com/turbo-sys/turbo_sys.html
I would personally use fuel injection to tie it together but many folks love carbs; really there is no right answer to that question.
You will need to get on Lorcan's webpage to get tuning info; but once you get that beast dialed in you will be able to keep up. If you cut down on the +100lbs your bike weighs over her's you may be able to beat her reliably that way.
you may want to brace the frame, undercut the trans, build the clutch, upgrade the suspension and brakes as well.... assuming you want actually control the beast you have just built.
I hope you have a good credit score, cause you will need it. And just remember; a factory zx14 is still gonna beat you up and take your lunch money!
::edit:: Please don't take the ribbing to seriously, there is no reason not to hot rod these old bikes; almost anything you do to a 30 year old machine will make a huge improvement. I myself have a healthy goal of a streetable, fun and easy to ride 100hp at the rear wheel. I fully expect to be looking into turbo kits before my build is done. Just don't expect to build a supersport killer easily or cheaply, such is life! ::/edit::
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
- KZ250LTD
- Thank you received: 16
My GF bought an '01 ZX-6R about a month ago. What do I have to do to my KZ750 to beat her from a stoplight?
Step 1:
Get a couple o' wrenches and a BFH
Step 2:
remove 750 engine
Step 3:
Use the BFH on the frame until it'll hold a zx-14 power plant
Step 4:
Bolt it in
Should work right up until the point where it bends the frame in half :woohoo:
79 KZ1000ST
Past:
Many.
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
- PLUMMEN
- Thank you received: 104
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
