Tires are worn out Thanks for your help
- mzandmz
09 Sep 2009 09:37 - 12 Sep 2009 18:28 #320150
by mzandmz
New to Family, 1979 KZ440 LTD
Tires are worn out Thanks for your help was created by mzandmz
When do you change the air in the tires? I counted how many times my tires go around in one mile and I've got over three thousand miles already on the back one.I know the stale air weighs more and can cause more brake wear due to heavier stopping. Also lighter air increases gas mileage by about 2% per mile.My friend told me to used only compressed air from a electronic air pump and make sure I put in 1/2 pound more so when I disconnect the hose it will be close to the right amount. Any better ideas?:dry:
Last edit: 12 Sep 2009 18:28 by mzandmz.
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
09 Sep 2009 10:27 - 09 Sep 2009 10:29 #320156
by tachrev
Build Thread
Replied by tachrev on topic Air change question
Stale air weighs more...huh? I've had same air in some tires for 20,000+ miles.
Also, I don't know how much I would worry about a half a PSI of pressure. I don't think you will ever notice unless you are racing, and maybe not even then.
Changing the air in your tires sounds like something you do when you replace the blinker fluid so that damn low blinker fluid light will stop flashing every time you turn the them on.
Build Thread
Last edit: 09 Sep 2009 10:29 by tachrev.
- Thank you received: 2829
09 Sep 2009 10:32 #320157
by 650ed
Replied by 650ed on topic Air change question
I might start using helium to improve fuel economy. (or maybe I should just diet and shed about 15 - 20 lbs.)
- fixer5000
- Thank you received: 5
09 Sep 2009 10:32 #320158
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic Air change question
one better idea...use nitrogen
massachusetts
- roy-b-boy-b
- Thank you received: 103
09 Sep 2009 10:59 #320160
by roy-b-boy-b
Replied by roy-b-boy-b on topic Air change question
:laugh: :laugh: :laugh:
- Buda
09 Sep 2009 11:16 #320161
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic Air change question
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- lapeerray
09 Sep 2009 15:30 #320225
by lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
Replied by lapeerray on topic Air change question
I am going to leave this one alone! Yes by all means you should use nitrogen.:woohoo: :woohoo:
- lapeerray
09 Sep 2009 15:32 #320227
by lapeerray
- Vter Bob
- Thank you received: 4
09 Sep 2009 15:35 #320231
by Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
Replied by Vter Bob on topic Air change question
If you do switch to nitrogen gas instead of air it's a good idea to mix a little Glade air freshener in. That way if you run over a nail and your tire passes gas it won't offend anyone.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
- KOOL RYDER
- KZ 650B2 / KZ 1000E
09 Sep 2009 15:39 #320233
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic Air change question
Why don't you fill them with hydrogen. That is the lightest gas you will find.
1978 KZ650B
1979 KZ1000ST
- trianglelaguna
- Thank you received: 235
09 Sep 2009 15:50 #320234
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Air change question
while others will laugh,it is only because they do not know the answer to your question,while i do!
After doing some checking i found that valantino rossi's bikes get the whole air in each tire flushed after each session....after every practice and before he goes out to set a qualifier lap,it's little known secret that old air not only begins to wheigh more but is less dynamic in suspension.
I change my air out before each ride and if there is a compressor handy at our destination,then i change it again before riding home,it makes a big difference.
1976 KZ900
2003 ZX12R
2007 FZ1000
- saltydog
09 Sep 2009 16:20 #320244
by saltydog
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
Replied by saltydog on topic Air change question
This is a joke, right?
