Western Canadians...How Many?
- TerryK
Re: Western Canadians...How Many?
28 Aug 2009 10:56
The West is over rated.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- irishwill
28 Aug 2009 14:50
TerryK wrote:
sorry I know thats below the belt.
I would still be in the Bay ( its beautiful ) if there were any opportunities there for me.
I still have my house there
And I do get back there every so often
and the last time you worked was...???The West is over rated.
- TerryK
28 Aug 2009 15:21
irishwill wrote:
lol ben, I was joking.
TerryK wrote:and the last time you worked was...???The West is over rated.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- oldcoldankles
28 Aug 2009 15:40
Hi Kenny - I'm from Peachland BC, on Okanagan Lake exactly ½ way between Kelowna and Penticton.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- KZ250LTD
28 Aug 2009 16:39
Hmm.. sounds like a western Canada KZriders rally is in order. Everyone be in Sandy's back yard by tomorrow night :laugh:
79 KZ1000ST
Past:
Many.
Past:
Many.
- Z1109R Fin
- kzkenny
- My wife says it's a sickness...
11 Sep 2009 12:01
Hey all, thanks for the responses, just got back from the coast last night and looks like the old girl will go right into the shop. She was running , shall we say poorly most of the way back. Pulled the plugs after about 300 kms and they were looking real lean and clean, had not much for top end and kinda choppy at about 120kmh.( surging) So start with the simple stuff fist I guess, change the inline filter, pull the petcock and check it there, check tank for crap. All part of the fun right...at least the ride down was a sweet one. I will contact a couple of you who are close by and see if we can do some rides, if too late this season maybe in the spring...
79 kz650SR, fenders and rear shocks from Z1000 classic
78 650c, clubmans, 750 engine,solo seat etc..
65 el camino
Puch scooter and other crap too numerous to mention...
65 el camino
- kzkenny
11 Sep 2009 12:10
Sandy wrote:
Hey Sandy, yes I was just down that way a couple of weeks ago, went from her to 100 mile house across to Little Fort, south to Kamloops, east to Revelstoke then south across the Arrow lakes to Nakusp then to Kaslo down to Balfour acroos Kootenay lake to Creston and then Cranbrook. That road from Crawford Bay to Creston was the best part of the trip, I think Destination B.C. rates it as the best ride in B.C. Lots of nice rides in your nieghbourhood....Down here,in the Kootenays,Kenny.
I was just up that way last summer,on the way back from Pigs Gorge.Went through Clearwater on the way up.Sure a nice ride through there...been a lot of years for me.
I was in Lillooet THIS summer when the fire started...couldn't believe how out of control it got. :ohmy:
You ever get down to this end of the Province?
65 el camino
65 el camino
- mzandmz
11 Sep 2009 12:16
Not enough AAAAAAAAAAAAAAAAh.:kiss:
New to Family, 1979 KZ440 LTD
11 Sep 2009 18:13
kzkenny wrote:
The reported symptoms might also result from a clogged vent in the fuel cap.
If not already done, could test run with fuel cap ajar (not snapped down), which allows the tank to vent regardless of any such clog.
Good Luck!
...looks like the old girl will go right into the shop. She was running , shall we say poorly most of the way back. Pulled the plugs after about 300 kms and they were looking real lean and clean, had not much for top end and kinda choppy at about 120kmh.( surging) So start with the simple stuff fist I guess, change the inline filter, pull the petcock and check it there, check tank for crap....
Good Luck!
- kzkenny
11 Sep 2009 21:08
Thanks for the tip Patton, my gasket on the cap leaks when the tank is right full and on the side stand. With that gasket being dried up like that would that allow enough air in? I'll will try your method in the morning, I'll also have a new inline filter here by then so I'll change it as well. How common is the problem you mentioned? and is that on both style tanks? mine is an SR. It's kind of strange because up till now she always ran fairly consistent and I didn't change anything then all of a sudden she started to run real lean, never has before. What would you suggest next if the fuel filter and venting issues don't fix the problem?...thanks..kzk
65 el camino
65 el camino
12 Sep 2009 01:12 - 12 Sep 2009 01:16
kzkenny wrote:
I concur with your ideas about checking out the petcock and tank and renewing the inline fuel filter. And only mentioned the vent as another possibility (easy to check).
Would remove petcock and clean the pickup tube screens that stick up inside the tank. If a manual petcock, would also remove and clean out the sediment bowl and the round filter screen (if the screen is still there).
Would also flush the tank, by removing it and dumping old fuel through the open cap, partially re-fill, shake it around, and dump again. All to remove whatever grit or crud might be floating around inside hovering over and collecting on and clogging the petcock pickups.
Here's a link to Z1E's Fuel tank cap GASKET
Good Luck!
...gasket on the cap leaks...if the fuel filter and venting issues don't fix the problem?....
Good Luck!
Last edit: 12 Sep 2009 01:16 by Patton.
