Build a part....
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- rstnick
- Thank you received: 377
If you were going to build, design or engineer a motorcycle part, what would it be and why?
I'd design an easy to swap on, and better braking system for the KZs.
A dirrect swap, just bolt on and go (or stop).
Just an upgrade for better braking, rotors that would fit KZ wheels and calipers that fit the kz forks.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- KawiConvert
- Thank you received: 4
So I will throw a smaller slave cylinder in there as well for what I would like to build. Something smaller with more travel than what I currently have.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- PLUMMEN
- Thank you received: 104
rocker arms would be so much easier to adjustPLUMMEN wrote:
if i was a machinist type id love to build myself a 16v head that looks like a stock z1/kz head,but im not so i wont!:laugh:
Now that would be some cool stuff! Small light weight valves at just the right angle. Would you use shims or rocker arms?
- Thank you received: 2829
- PLUMMEN
- HenryKrinkle
Does anyone know of a place I can find this now?
- StreetfighterKz
- Thank you received: 117
An adapter plate or even whole hub that would accomodate modern front rotors and still run spokes. That would be perfect.
Klasmo used to sell hubs that fit Kz spoked rims to Gsxr/ZX/Zrx forks but I think they discontinued them due to the high cost that noone would pay for.
KawiConvert wrote:
If I had the time and money I would love to find a way to make a hydraulic clutch adapter for the stock cover.
Check out my 1000. I was able to place a Zx7 slave inside my stock cover without welding and without too much grinding to the webs. It's not the prettiest but it works well and you can't tell it has hydraulic clutch except for the M/C on the handle bars.
I've designed some parts for my 900. I haven't gotten around to machining the parts but I have 95% of the material needed.
I'm designing my own outboard bearing support with provisions for a hydraulic clutch. It'll also cover up more than the DG or Kosman supports do. I hate the big gaps and the fact the bottom of the starter motor is always hanging out.
I've also designed my own swingarm extensions. I did this for a couple reasons. 1) I can pick up the material and machine it with the help of some buddies for about 25% what some companies charge to do it for you. 2) I can design it to my specs i.e. axle size, caliper hanger, chain adjustment methods, etc. 3) I can say I designed and made it myself if someone asks.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- PLUMMEN
ive already got that one lined up,just need to find rotors with right offset.An adapter plate or even whole hub that would accomodate modern front rotors and still run spokes. That would be perfect.
