Traffic light triggers
07 Feb 2009 21:38 #262828 by KZErider
Traffic light triggers was created by KZErider
I've seen these things advertised which are supposed to trigger the pressure sensors(?) at intersections so the lights will change. Has anyone tried these? Do they work?
Late the other night I sat in the left turn lane for what seemed too long with very little cross taffic. Anything else one can do about it?:unsure:
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
07 Feb 2009 21:52 - 07 Feb 2009 22:00 #262831 by Patton
Replied by Patton on topic Traffic light triggers
KZErider wrote:
... Anything else one can do about it?:unsure:
I know what I do about it! :woohoo: :laugh:
Here's a link with some good comments about the video sale's pitch.
Trigger-Smigger
Good Luck! :)
Last edit: 07 Feb 2009 22:00 by Patton.
07 Feb 2009 23:04 #262837 by hobbyfarmer
Replied by hobbyfarmer on topic Traffic light triggers
I dont know about your state but in Minasota if the light go's through to cycles you are aloud to just run the light!
:laugh:
07 Feb 2009 23:46 #262843 by PLUMMEN
Replied by PLUMMEN on topic Traffic light triggers
i used to install traffic lights and wiring years ago.1st off it has nothing to do with pressureor weight of vehicle there are loops cut in the concrete with wire looped around inthe square/loop 3-4 times if i remember right.anyway this puts off a magnetic field from the electricity passing through the wires,when something large and metal like a car drives over the loop the magnetic field is disturbed and sends a signal back to the control box which intern sends a signal to the lights to change,thats a very basic explanation of how it works.B)
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
07 Feb 2009 23:53 - 07 Feb 2009 23:54 #262846 by kzz1p
Replied by kzz1p on topic Traffic light triggers
There is a video on utube about it. A kid uses a magnet on a string hangging under a car. I only watched it (no sound) so I don't know what kind of magnet?
Last edit: 07 Feb 2009 23:54 by kzz1p.
08 Feb 2009 00:14 - 08 Feb 2009 00:14 #262853 by PLUMMEN
lay a piece of sheetmetal on top of the loop detector and it will change :laugh:
Last edit: 08 Feb 2009 00:14 by PLUMMEN.
08 Feb 2009 05:33 #262861 by Bluemeanie
Replied by Bluemeanie on topic Traffic light triggers
Pull up to the "circle" with your engine/frame sitting over the 9 o'clock posistion and you'll have no problem. Don't waste your money on these gadgets!
08 Feb 2009 07:07 #262879 by otakar
Replied by otakar on topic Traffic light triggers
Plummen is right, it works on a magnetic field. I installed an old magnet from a speaker on the front of my center stand. When you fold up the center stand it than places the magnet at the lowest point on your bike with the exception of the bottom of your header. This now works exactly the same as the advertised product. Old speaker magnets are easy to find and usually FREE (this is always good) Just remember two things 1) mount it as low as possible and, 2) use as large and powerful magnet as possible. The system is sound and it works, just don't spend your money on something you can get for free. You can use as many magnets as you want, and if you space them it is even better.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • trianglelaguna
08 Feb 2009 07:14 #262880 by trianglelaguna
Replied by trianglelaguna on topic Traffic light triggers
like fonzy popping the jukebox.....i have some tricks too...but they may be state specific....and they may be me just doing somthing i THINK works.........in California most left turn waiting lanes have a piture of a bicyclist painted in yellow lane paint and a square ...you stomp your foot on it and it triggers the light........if it's not there i grab my front brake and stand up (like a burnout) and rock the kz back and forward hard...seems to trigger it too....my favorite is to look at traffic as i come to the intersection and choose to lower my knee and blow thru it like i'm at seca...that is the best way......i am not gonna sit in a freeway turn lane waiting for some dude on meth/booze/or his phone to clip me....:woohoo:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • H2RICK
  • Is this a fun bike, or what!!!
08 Feb 2009 18:18 #263077 by H2RICK
Replied by H2RICK on topic Traffic light triggers
Yep, John, I have a left turn bay that I ride through on the way to work and I finally figured out after some experimentation that that's what triggers it....for some reason. I don't know why the left side works and the right side doesn't.....but that's the way it does.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
08 Feb 2009 18:28 #263079 by grumpy56
Replied by grumpy56 on topic Traffic light triggers
I put my kickstand down and let the bike rest on it for a second or two. Usually works.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
08 Feb 2009 18:58 - 08 Feb 2009 19:06 #263089 by Patton
Some emergency vehicles such as fire trucks are equipped with some sort of device whereby the driver approaching a traffic signal can change it to green.
Wonder where can I get one? :laugh: [The device -- not a fire truck.] :pinch:
But what happens when Plummen's heading West and I'm heading North, both approaching the same traffic signal, and both pressing our device buttons? :( I want the strongest most powerful device available, and hope Plummen keeps using his econo version. :laugh:
But oops, what if Plummen's driving a fire truck! :ohmy:
Last edit: 08 Feb 2009 19:06 by Patton.
