Okay- Newbiker got the KZ750F
  • CruisingRam
  • CruisingRam's Avatar Topic Author
24 Sep 2007 22:35
#172689
Ethan just bough a KZ750F, according to the VIN
It also says "KZ750DF" if anyone can help a brutha.
Post edited by: CruisingRam, at: 2007/09/25 01:56
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
Re: Okay- Newbiker got the KZ750F
25 Sep 2007 00:24
#172692
Ahhhh, okay. That's basically a Spectre, but with the LTD paint & chrome scheme. That's a 1983 model, right? The peg mounts are a bit different, so my ghettotech method would have to be altered and adapted to that application if that's what you want to do. That looks pretty similar to the KZ550-M that Trav has, but he grafted on modern rearsets from some sport bike of recent vintage.
I'd recommend a superbike or clubman bar, some sort of rearsets, Progressive springs up front (or a GPz750 fork), some nice shocks in back, and some sticky tires. Change out all the bearings, maybe paint the wheels and frame, get some sexy turn signals. That bike should have come with an electric tach, so GPz750 cams will drop right in, same with Mikuni BS34s. An '82 GPz 750 or 1000 tank should bolt right on, as would the tank from a 1000 MkII (if you can find one). Hell, the GPz seat might even plop right on there too, I don't know, there might be differences in the rear subframe.
Cool, man! Keep us posted, take lots of pictures!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • CruisingRam
25 Sep 2007 00:27
#172693
You have pics of the gpz tank? And maybe seat?
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
25 Sep 2007 05:51
#172718
Here is a pic of my 83 L-3 which has the same tank and seat as an 82 GPZ 750. You might get the tank to work but the seat is doubtful since the frames are totally different. Also that bike should already have the BS 34 Mikunis on it.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • CruisingRam
25 Sep 2007 09:26
#172752
I don't think we will use the gpz tank on this one- I like the roundy-er one, and so does NB- I found a tank and front fender on e-bay
Will GPZ550 forks be an improvement on handling?
Post edited by: CruisingRam, at: 2007/09/25 12:33
  • OKC_Kent
  • OKC_Kent's Avatar
25 Sep 2007 10:16
#172763
CruisingRam,
That's the same bike I have under construction now. Can I ask you to post a pic of the top of the forks? Mine may not be stock to the LTD and I need to see the air setup.
Thanks
Kent
Cashion, OK
78 KZ650 B2 85,000+ miles
  • CruisingRam
25 Sep 2007 13:38
#172801
Sorry, I replaced the forks with some other ones, they are not stock!
  • guitargeek
26 Sep 2007 09:49
#172946
What fork did you use?
  • CruisingRam
26 Sep 2007 11:19
#172965
Another LTD fork, but it is not quite the same- I don't think he described it quite rigt on the e-bay add- but it bolted in,but it doesn't seem to have an aircrossover
  • OKC_Kent
  • OKC_Kent's Avatar
26 Sep 2007 11:50
#172969
My fork does not have an air crossover, and the fork tubes do not have any type of airhole in the side. The schrader valves are recessed slightly up at the top, about 3/4" down in the tube.
How do I remove this in order to remove the fork springs, or measure oil level, etc? I have to replace the seals and clean up the tubes.
Cashion, OK
  • cafekz750
  • cafekz750's Avatar
28 Sep 2007 13:13
#173354
My KZ750LTD has fork caps that thread onto the fork tube. I worked on my brother's KZ550LTD that had a recessed air valve on the top of the fork. To access the springs and oil, you have to jack up the front wheel, push down on the cap (really hard depending upon the condition of the forks) and pry out a c-clip retainer like on a piston/wrist pin combo. I hope this helps.
Good Luck.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
  • OKC_Kent
  • OKC_Kent's Avatar
28 Sep 2007 19:38
#173414
Thanks cafekz750, I'll try that. It sounds like my fork setup.
Cashion, OK
