turbo project
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: turbo project
10 Mar 2007 11:30
#118984
If you can find them, go with an 18 front and a 17 rear. They look real good on the KZ's and still have a ton of tire choices. I went with a 120/70-18 up front and a 180/55-17 rear. (I had a 16" KZ rear mag widened and increased 1" in diameter to 17" and had a std Z1-R 18" front widened to 3.5 wide). There are several aftermarket fenders that look great on the 18" front (I even have an extra one or 2 if you are interested):whistle:
The Kaw List:
  • wireman
  • wireman's Avatar Topic Author
Re: turbo project
10 Mar 2007 12:16
#118995
got a picture of them?;)
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: turbo project
10 Mar 2007 14:22
#119036
Check you PM wireman!
The Kaw List:
  • wireman
Re: turbo project
10 Mar 2007 16:25
#119056
got it,thanks;)
  • 77KZ650
  • 77KZ650's Avatar
Re: turbo project
16 Mar 2007 23:06
#120940
hows the fender hunt? thought about a zephyr fender? pic in this LINK
07 MDP Rookie of the Year
  • BohicaBob
  • BohicaBob's Avatar
Re: turbo project
17 Mar 2007 04:47
#120954
wireman - "my biggest problem with the 17" front wheel is trying to find a front fender that matches the radius of the front wheel and still retains a z1/kz look to it." I faced that exact problem but I found a front fender from Klasmo and made it fit the front forks on my '73 Z1-900. Later I found that AmericanClassix.com in the US sells the same front fender. But fitting this expensive front fender is not a trivial exercise I must tell you.
  • wireman
Re: turbo project
17 Mar 2007 09:55
#121002
im thinking about going with the 18" front and 17" rear combination,im not gonna be laying this bike into corners at 140 although i will be occasionally doing that in a straight line:evil: :P im trying to keep this bike looking as much like the old hotrods that ran the streets in the 70s and 80s when i was a young wildman riding on em,so im gonna try and modify a steel ltd fender by widening it just a little to clear a 120 front tire and replating it im also gonna widen a stock z1 steel rear fender to match the rear tire and plate it;) ah nostalgia!;) :P
  • racer54
  • racer54's Avatar
Re: turbo project
17 Mar 2007 20:59
#121172
Wireman...check out an LTD fender from an early KZ1100 LTD. I believe they are about 1/2" to 1" wider then the LTD fender off a KZ1000 LTD. If anyone has one they can measure it, but I'm sure they are wider. One of those should fit a 120 tire. The forks have a wider spacing I know so the fender should be wider also.
  • wireman
Re: turbo project
17 Mar 2007 21:31
#121181
cool,thanks!;)
  • fatkow
  • fatkow's Avatar
Re: turbo project
25 Jul 2007 20:32
#159698
9487 posts cool,thanks!;)
