‘79 Kz650B3 Resto-mod
  • StreetfighterKz
  • StreetfighterKz's Avatar Topic Author
19 Jan 2025 08:36 - 19 Jan 2025 08:42
#908045
I picked this bike up a couple years ago for $175 with a BoS.  It was complete minus an airbox, gas cap, and right driver footpeg.  It was rough but solid.  Took me 2yrs to finally get a title (rather long boring story).  So I’ve been working it on/offon it for those two years.  I do quite a bit of sidework to fund my projects but that doesn’t leave me much time for my own bikes.
Anyways, here it is the day I brought it home.
To be continued…
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 19 Jan 2025 08:42 by StreetfighterKz.
  • StreetfighterKz
Re: ‘79 Kz650B3 Resto-mod
19 Jan 2025 08:42
#908046
My goal when I started was sort of a street-legal trackday bike.  I had collected a bunch of parts to do the same thing to a ‘76 Kz900 frame I had in storage but I don’t have a title for it so I decided the 650 would get the parts instead.
Some inspiration that I found:
To be continued…
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
19 Jan 2025 13:05
#908052
I have tons of pics from the last two years and put in a bunch of work, time, and custom touches.  It’s hard to capture all the mods but here is roughly how it sits in the mock-up phase.
If there is anything specific you have questions about, I’m sure I have pics and info about it.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Injected, ThatGPzGuy, sf4t7, Dragbike_Mike
  • ronnieV
  • ronnieV's Avatar
20 Jan 2025 04:31
#908068
Lovin it so far.My cousin back in the day was into the 650s and he built a few that were gorgeous.
The following user(s) said Thank You: StreetfighterKz
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
20 Jan 2025 09:33
#908072
Interesting project. I do have a question regarding the machine as you brought it home. It appears to have already been altered from stock B3. None of the B models had a disk on the rear wheel, and it appears to my eyes that it has a 16 inch rear tire, again not stock on the B models.
I do like the look of your mock up, and it looks like it would be fun to ride. I look forward to following you on your build.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • StreetfighterKz
20 Jan 2025 09:57
#908076
You are correct. The seller also had a 650 SR in the same shed. I didn’t take a close look but I think I remember seeing spoked wheels on it. Mine did have a booger welded rear M/C mount on it, but the VIN is Kz650B-xxxxxx.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
10 Feb 2025 20:36
#908891
Blew the bike apart and placed the engine on my stand. I’m wanting to scrub the engine down some while it’s out of the frame. It actually pretty clean but has some dirt and grime in the hard to reach spots, of course.
To be cont’d.…
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: ThatGPzGuy, MFP-Joe, Dragbike_Mike, kimchella
  • StreetfighterKz
10 Feb 2025 20:36
#908892
 I finished cleaning up the frame where I de-tabbed it earlier and decided to remove the centerstand mounts while I could flip the bare frame around easier.
Then I turned up a tach drive plug. It doesn’t look super fancy and took me almost 1.5hrs but $0 spent.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Injected, Wookie58
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
11 Feb 2025 04:43
#908902
Very fine engine stand, thanks for share the pics! ( So i have to do build me a similar  stand, looks really great and functional!)
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • StreetfighterKz
11 Feb 2025 16:26
#908935
It’s a K&L stand I've had for 20+ years and used it maybe twice. I can’t remember what I paid for it but they’re $300+ now.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • StreetfighterKz
18 Dec 2025 12:58 - 18 Dec 2025 13:03
#919924
It seems as if 10 months have now passed and I’ve done jack squat with my 650.
I was able to find a painter so I should be dropping off the bodywork in the next week so he can start prepping it for paint. Before doing so, I needed to open the stock fuel tap hole up slightly to fit the Pingel petcock I plan on using.
Hopefully the next update will show a painted set of bodywork.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 18 Dec 2025 13:03 by StreetfighterKz.
The following user(s) said Thank You: Injected, Dragbike_Mike, Wookie58
  • StreetfighterKz
24 Feb 2026 13:46
#921713
The color’s laid down.  It’s a bit darker than I was hoping but still not bad.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Injected, Dragbike_Mike, Wookie58, kimchella
