Starting restoratin project KZ650
  • Injected
  • Injected's Avatar
Re: Starting restoratin project KZ650
06 Oct 2024 15:17 - 06 Oct 2024 15:19
#904908
I was going to check the rubber damper on the secondary shaft but the 3 Allen head bolts holding the starter motor clutch on will not budge, been applying RP7 over the last couple of days but I think if I try too hard they will snap. They are clean no corrosion just very tight. Any suggestions, I don't  want to apply too much heat because of the rubber damper.
I believe those original dampers are no longer available but the dampers from the ZR7 series machines are the same size, Kawi PN 92075-1227
You may be able to verify that info by using the search function.
1978 KZ650B2 modified project
Last edit: 06 Oct 2024 15:19 by Injected.
The following user(s) said Thank You: Vietvet
  • Injected
  • Injected's Avatar
08 Oct 2024 16:40
#904960
Found the damper reference :
www.kzrider.com/forum/11-projects/610746...cafe-racer?start=324
About half way down that page.
  • Nessism
  • Nessism's Avatar
  • Away
08 Oct 2024 16:57 - 08 Oct 2024 17:03
#904964
Those dampers are in the secondary shaft.  Partzilla lists them as still available.  Another huge improvement can be gained by changing the rubber dampers in the clutch.  A guy on the KZ750 Turbo site sells them, or at least he used to.
After being out of stock for a couple of weeks I'm glad to announce I've got a fresh batch of Viton dampers ready to ship.
The cost is still $45 US for a set of six. Shipping costs can be found in earlier posts.
So if you're interested contact me at turbosteve84 "at" verizon.net. I'm in the US.
Thanks,
Last edit: 08 Oct 2024 17:03 by Nessism.
