- Thank you received: 1918
73 Z1 mutt/mixed breed Build
22 Jun 2024 18:00 #901152
by Mikaw
Replied by Mikaw on topic 73 Z1 mutt/mixed breed Build
One of my many projects is the same fact. They preferred to build up weld.All the welders I have used preferred to build up the fin rather than weld on a piece from another head. But I"m sure there have been others who have welded in donor fins
The following user(s) said Thank You: SWest, Coyote
- Coyote
- Thank you received: 22
13 Jul 2024 10:02 #902060
by Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
Replied by Coyote on topic 73 Z1 mutt/mixed breed Build
My new inner fort tubes are arriving today 36mm OD. I made yet another mistake and ordered stock Z1- KZ 900/1000 length tubes before measuring the length of the ones I have. Stock length is 24 1/4" or 24 3/16". The ones I have are 22.xx". I have another set of lower tubes without the inner tubes and measured the length of both pairs of outer tubes. The outer tubes that had the short inner tubes installed are about an inch shorter than the pair of outer tubes that don't have inner tubes. My question is, are the short forks from something other than a Z1 or KZ? Is there any detailed reference specs for Z1/KZ forks?
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- asphalt900
- Thank you received: 274
14 Jul 2024 02:09 #902070
by asphalt900
Replied by asphalt900 on topic 73 Z1 mutt/mixed breed Build
You could have some 36mm tubes from an H2 or triple. That was a common theme back in the day to drop the front end down a couple inches.
The following user(s) said Thank You: Coyote
- Thank you received: 1088
14 Jul 2024 03:34 #902071
by hardrockminer
Replied by hardrockminer on topic 73 Z1 mutt/mixed breed Build
KZ650 forks are exactly the same length as Z1 or KZ1000 forks, but the tubes and lowers are different lengths. But I can't recall if they are shorter. The tube inner guts are different.
- slmjim+Z1BEBE
- Thank you received: 732
14 Jul 2024 05:32 #902074
by slmjim+Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Replied by slmjim+Z1BEBE on topic 73 Z1 mutt/mixed breed Build
Lower fork tube length is identical on all our Z1's, '72 thru '75.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Coyote
14 Jul 2024 09:36 #902098
by Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
Thank you for the info provided by those who responded to my fork question. Here is a picture of what I have. The short ones are on the left with guts and the correct lower is on the right with the new inner tube. The mainspring length is 343 mm. I took both lowers and compared them with what's on my 77 and the one on the right matches it. My 77 manual says the mainspring should be 521 mm. Unfortunately, I do not have the guts to the lowers on the right and the lowers on the right are chromed and the chrome is not in very good shape.
Starting to get a little discouraged at this point. My next step is to evaluate the 76 frame I have, if it's straight I'll proceed. If it's bent, I'm probably going to give up and start selling parts:(
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
14 Jul 2024 20:27 #902126
by Mikaw
The Z1 forks have the reflector built in. The two examples you’re showing are 1976 and newer. What exactly do you need I have sever forks around I might be able to help.
- asphalt900
15 Jul 2024 09:10 #902144
by asphalt900
Just my half-penny advise but since You have a 1973 Frame/Powerplant and "kinda" put the cart in front of the horse purchasing the NOS tank, why would one resort to later fork lowers? What is going to happen, and believe me it's always going to be yours but.. Take Matt's advise, keep it a true 1973. You'll wreck a 20K bike into a 3K bike immediately. But..as long as you don't mind it? It'll still drive and ride the same.
- Coyote
15 Jul 2024 09:55 #902147
by Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
Thanks Mikaw, I guess I need the guts for the longer forks at the least, and the lowers with reflectors preferably. See my next reply for my other thoughts.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- Coyote
15 Jul 2024 10:21 #902148
by Coyote
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
Yep, I agree with your thoughts. It was a real bummer finding out the 73 frame is bent. Guess I should research getting that 73 frame straightened. The more I think about it, it doesn't make sense to use the 76 frame.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
- asphalt900
15 Jul 2024 11:13 #902151
by asphalt900
Don't fret!! I have a fella that can straighten that 73 frame!!
- asphalt900
15 Jul 2024 11:18 #902153
by asphalt900
Actually you could pull it into submission yourself if you have a bit of interest doing so. AS Long as the head is not collapsed towards the rear. If it's just tweaked side to side as shown in pics posted, not a big deal.
