73 Z1 mutt/mixed breed Build
19 Jun 2024 11:10 #900976 by Coyote
Replied by Coyote on topic 73 Z1 mutt/mixed breed Build
Found another issue, is it me or does this frame look bent? Looks like the steering head is twisted counter clockwise by a few degrees
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
  • Kelly E
  • Never Give Up. Never Surrender
19 Jun 2024 11:21 #900977 by Kelly E
Replied by Kelly E on topic 73 Z1 mutt/mixed breed Build
It does look that way in that picture.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: Coyote
19 Jun 2024 11:39 - 19 Jun 2024 11:41 #900979 by Wookie58
Replied by Wookie58 on topic 73 Z1 mutt/mixed breed Build
Not sure if it's the frame or the trees but something looks off - you could try laying a flat board against  the front of the trees, if the are off the board will rock "corner to corner"
Last edit: 19 Jun 2024 11:41 by Wookie58.
19 Jun 2024 12:56 #900981 by Coyote
You nailed it Wookie! Let me take it back apart and see what's up with that, I'll let you know
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
  • Kelly E
19 Jun 2024 14:01 #900989 by Kelly E
Before you tighten the triple tree bolts clamp the front axle in place. It will help to hold the front end in alignment.
1983 Honda CB 1100F
And more
19 Jun 2024 15:08 #900996 by Coyote
Will do, thanks
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
19 Jun 2024 20:35 #901004 by Mikaw
Replied by Mikaw on topic 73 Z1 mutt/mixed breed Build
The rear sprocket carrier/Cush drive is wrong for the Z1 hub. From the picture it looks like it’s from a mag wheel. Your ‘77 if it’s a Kz1000 and OEM will not work either, that hub had disc not drum. Any thing for a H2750 to a 1977 kz900 will be correct. As for the front I see your Rh (left) as pictured upper stantion is higher in the steering stem head then the LH. As mentioned install the axle to help. Set the flange of the fork top bolt flush with the strewing stem head (upper tree). It would take a pretty good hit to twist the head tube. Also I see the steering stop pin looks straight. But as pictured it do warrant a deeper investigation.
19 Jun 2024 20:37 #901005 by Mikaw
Here is the proper orientation of the rear spacers.
19 Jun 2024 20:47 #901006 by Mikaw
The lower carrier/Cush drive is what you want, the upper is for a mag wheel.
The following user(s) said Thank You: sf4t7, Coyote
20 Jun 2024 05:47 #901021 by Coyote
Thank you for the pictures, that helps, you don't happen to have one for sale by chance?
The front forks in the picture are not the ones I'll be using, they're just some old ones that came with the big parts purchase earlier. I wanted to get the wheels on the frame before I put the engine in. The reason the right fork appears higher in the tree is the cap is halfway off. I haven't been able to break the left fork cap free yet. I really just want to use the internals. I'll be pulling the triple tree back apart this afternoon or tomorrow to see where I messed up.
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
20 Jun 2024 14:48 #901044 by Mikaw
I do not have one for sale but I’m 100% sure this guy will. I buy from him.
www.facebook.com/jake.cooper.129142
21 Jun 2024 08:41 #901071 by Coyote
Lower tree has a twist
77 KZ 1000 A
21 Z900 RS
Project 73 Z1
