- Thank you received: 348
‘76 KZ900 LTD restoration
- sf4t7
07 Nov 2023 13:16 #891424
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Replied by sf4t7 on topic ‘76 KZ900 LTD restoration
Motomisfit - you'll find this forum has a good mix of restore guys and modify guys. In 1979 my friend's Z1 scared the crap out of me, soon after I had one too.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
- Thank you received: 2059
07 Nov 2023 14:22 #891429
by Street Fighter LTD
Replied by Street Fighter LTD on topic ‘76 KZ900 LTD restoration
- motomisfit
- Thank you received: 49
08 Nov 2023 19:27 - 08 Nov 2023 19:28 #891500
by motomisfit
Replied by motomisfit on topic ‘76 KZ900 LTD restoration
Last edit: 08 Nov 2023 19:28 by motomisfit.
- motomisfit
08 Nov 2023 20:01 #891501
by motomisfit
- Thank you received: 2301
08 Nov 2023 23:51 #891505
by Wookie58
Replied by Wookie58 on topic ‘76 KZ900 LTD restoration
You could consider a layer of "scrim" foam (2mm of foam on a linen backing) to smooth it out before fitting the cover ( see page 11 of my build thread, link is in my signature) it's thin enough to not effect how it looks but ties the foam together
The following user(s) said Thank You: Nessism, motomisfit
- sf4t7
09 Nov 2023 04:59 #891511
by sf4t7
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Maybe that plastic film served the same purpose as the scrim Wookie mentioned with the added function of keeping the foam dry. Just a guess. Believe it or not sometimes these old bikes were left out in the rain. Might be a good idea to do both.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
- motomisfit
09 Nov 2023 14:17 #891527
by motomisfit
Thanks Wookie. Did you glue the scrim foam to the existing foam or pad? Was that a seam you had to make because of the “crown” on the top of seat?
09 Nov 2023 14:47 - 09 Nov 2023 15:37 #891528
by Wookie58
The scrim is glued down with spray "evo-stick" (as it remains flexible when dry) start in the middle and work out, it's quite flexible so the only seam was "front to back" on the top of the hump. I worked out from the middle gently stretching the scrim as I pushed it into place so there weren't any creases then split the scrim on top of the hump, laid one side over the other and cut through both pieces so it laid down flat and even.(hope this makes sense) the black line in the picture was to show the trimmer where I wanted the seam in the cover. L don't know if you saw the end result but it was worth the effortThanks Wookie. Did you glue the scrim foam to the existing foam or pad? Was that a seam you had to make because of the “crown” on the top of seat?
Last edit: 09 Nov 2023 15:37 by Wookie58.
- motomisfit
09 Nov 2023 19:34 - 09 Nov 2023 19:34 #891533
by motomisfit
Wow nice job. I’m hoping mine turns out as well. I’ve had good luck with the 3M high strength and it stays kinda rubbery when it dries. I am for sure going to find some of that foam.
Last edit: 09 Nov 2023 19:34 by motomisfit.
10 Nov 2023 01:10 - 10 Nov 2023 01:14 #891536
by Wookie58
Not sure if my explanation was all that clear so I thought the below might help, you don't get too many chances with "contact adhesive" so the order I smoothed the scrim down in is
Green - Blue - Yellow - Purple (the thin red line is the only seam where I had to remove some material) once it's all stuck down you can trim the excess with scissors or a sharp blade
You should be able to get the "scrim" from an upholstery supplier (it's not unique to the automotive world, furniture makers use it to give a "quality feel" to upholstered hard surfaces)
Last edit: 10 Nov 2023 01:14 by Wookie58.
The following user(s) said Thank You: sf4t7, motomisfit
- motomisfit
10 Nov 2023 07:47 #891543
by motomisfit
Perfect. Well done. I get it now, the black line was just a felt pen line. The scrim foam is simply foam with a backing so that it can glued and stick better. With some luck I’ll have mine done this weekend and post some pics. Thanks again
- motomisfit
10 Nov 2023 19:52 #891560
by motomisfit
Got my foam today. College football and seat work tomorrow. What a better way to spend a Saturday
