KZ650 Sleeper Build (KZ1000 engine transplant)
  • Injected
  • Injected's Avatar Topic Author
Re: KZ650 Sleeper Build (KZ1000 engine transplant)
29 Aug 2026 13:46
#927096
I had some time today so I was able to work on this bike again.
I swapped out the #1 float valve, it was "sticking" intermittently when I moved the float up and down. When I removed it there was some crud on it but the tip looked OK. There was also some binding on the spring pin end as well so I suspect there may be tarnish buildup in there. I replaced it with a NOS matching assembly.
When I changed it out I also replaced whatever gasket I could easily reach with new ones, which was about half of them.
I did a "wet" test with some alcohol and all is good now.
Drained the alcohol and will try to get a ride in tomorrow if no other issues arise.
1978 KZ650B2 modified project
The following user(s) said Thank You: Nessism, Wookie58
