Project: 1990 ZR550 Zephyr (yes, another one)
- Stereordinary
Re: Project: 1990 ZR550 Zephyr (yes, another one)
21 Apr 2023 22:27
Since my cam cover situation is on hold (different thread), I decided to try and button it up with what I have. I checked to make sure it would turn over, checked the cam chain timing, and valve clearances. Everything checked out so I installed the stock cover and called it good. I suppose it’s entirely possible that there’s something somewhere in the engine that the PO didn’t torque to spec or remember to oil/grease, but as it sits right now I’m gonna take that risk, fill it, and fire it.
A breeze from the west.
‘90 ZR550 Zephyr
‘90 ZR550 Zephyr
- howardhb
- God, I trust
22 Apr 2023 03:16
Remember to remove the cam chain tensioner cap and spring BEFORE tightening down the cam cover. The chain runner in the cover presses down on the chain, between the two cam sprockets.
H.
H.
'81 GPz 550 D1
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/11-projects/617040-1981-...-rstomod-elr-tribute
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: Nessism, linuxrob, Stereordinary
- Stereordinary
22 Apr 2023 09:25
Ah crap, you’re right, I totally forgot. I can still remove the tensioner, reset it, and reinstall it right?
‘90 ZR550 Zephyr
‘90 ZR550 Zephyr
- howardhb
- God, I trust
22 Apr 2023 12:05 - 22 Apr 2023 12:09
Yes, remove the cap and spring, then slowly rotate the crank backwards about half a rev and reinstall the spring and cap, to allow the tensioner to extend into the "slack" and you should be good. (Be aware that the starter will be driven by the the reverse rotation)
H.
H.
'81 GPz 550 D1
Last edit: 22 Apr 2023 12:09 by howardhb.
The following user(s) said Thank You: Stereordinary
- Stereordinary
23 Apr 2023 13:56
Resetting the cam chain tensioner to find that I have a stripped cap bolt. Or rather, the threads the cap bolt thread into are stripped. Luckily I should still have the tensioner I replaced on my other bike. See? I knew there was a good reason to have two of the exact same bike.
‘90 ZR550 Zephyr
‘90 ZR550 Zephyr
- Stereordinary
09 May 2023 14:02
‘90 ZR550 Zephyr
‘90 ZR550 Zephyr
The following user(s) said Thank You: Nessism, Wookie58, Kelly E
- Kelly E
10 May 2023 08:34
Nice job on the painting parts rack.
I use two 12' lengths of perforated angle iron for hanging garage door openers. One for all of the parts and one to hang the frame from.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
10 May 2023 08:55
- Kelly E
10 May 2023 14:16
Thanks Wookie, it's 1400sqft with 12' 6" ceiling height and heated. It's big enough to share work space with two of my friends.
1983 Honda CB 1100F
And more
1983 Honda CB 1100F
And more
- Stereordinary
10 May 2023 21:15
Consider me jealous. I make do with the little bit of space I have, but it would be nice to spread out a bit more.
‘90 ZR550 Zephyr
‘90 ZR550 Zephyr
- Stereordinary
11 Jun 2023 20:53
Painting went well I’d say.
The fender is painted brown as well, but I need to rivet it back together with the brace still. I also have some ideas for a tank badge/decal.
Tomorrow I’m gonna pick up some oil, a battery, and some gas, and see if she starts.
‘90 ZR550 Zephyr
‘90 ZR550 Zephyr
The following user(s) said Thank You: rstnick, gordone, howardhb, Wookie58, Moose1800
- Moose1800
12 Jun 2023 08:25
Wow, you've made a lot of progress in a very short time! Good luck on the first start up I know how nerve racking that can be with an unknown bike.
One question....is the front tire installed in the right direction? I always thought the tread should wick the water away from the center of the tire.
