76 KZ900
- mvent
76 KZ900
06 Mar 2023 16:07 - 06 Mar 2023 16:12
Picked up this one owner KZ900 today, 9800 miles parked in 2003. Will start picking away at it soon I planned to clean carbs and put battery in to check mechanical and electrical out and go from there.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Last edit: 06 Mar 2023 16:12 by Street Fighter LTD.
Re: 76 KZ900
06 Mar 2023 17:20
Very solid. Just FYI, it has Z1A-B carbs.
The following user(s) said Thank You: mvent
- mvent
Re: 76 KZ900
06 Mar 2023 17:45
Mikaw thanks for that, would have been a problem when ordering carb parts.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Re: 76 KZ900
06 Mar 2023 17:52 - 06 Mar 2023 17:54
Pull the plugs and put marvel mystery oil in them while you work on other stuff. Open the carbs and post pictures. Don’t butcher them up by trying to install “Kits” I’d be willing to bet, unless they are completely trashed, that you can reuse all the brass. Nessism should be able to help you with ORings, buy good gaskets. No rubber evilbay stuff. Go to Jets r Us, Nichecycle or Sudco.
Last edit: 06 Mar 2023 17:54 by Mikaw.
Re: 76 KZ900
07 Mar 2023 03:14
Hard to believe there are still gems like this sitting in sheds waiting to be rescued, looks completely unmolested (except by critters !!)
The following user(s) said Thank You: MLMG
Re: 76 KZ900
07 Mar 2023 04:15 - 07 Mar 2023 05:03I’m jealous. I’d love to find a jem like this. I’d do a mechanical restoration and drive it as is.
Last edit: 07 Mar 2023 05:03 by Mikaw.
- blipco
- 2002 KZ1000P
Re: 76 KZ900
07 Mar 2023 07:31
You really have something here.
How is the inside of the tank I’m afraid to ask?
- gd4now
- Denco where did you go?
Re: 76 KZ900
07 Mar 2023 09:16
Agree with all said. You have found yourself an interesting machine. I look forward to seeing more as you get to know it better.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- mvent
Re: 76 KZ900
07 Mar 2023 16:18
Tank that's on the bike I don't believe is original to bike, it appears to have been coated and looks real good. Also have an original paint tank which was probably the original, coating inside is flaking off there are no soft spots at all and paint is pretty good. Under the seat was the tool kit, owners manual with warranty kard ( spelled with a k )
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
- Moose1800
Re: 76 KZ900
08 Mar 2023 08:13Nice find indeed, I find it odd that it has early VM28's on it with it showing such low miles. Would be interesting to see the engine ID#.Very solid. Just FYI, it has Z1A-B carbs.
- mvent
Re: 76 KZ900
08 Mar 2023 11:45 - 08 Mar 2023 12:4676 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Last edit: 08 Mar 2023 12:46 by Street Fighter LTD.
- mvent
Re: 76 KZ900
09 Mar 2023 16:38 - 09 Mar 2023 16:56
Removed carbs to clean, must have been drained of fuel before parking, jets look good but inlet throats on a couple of carbs had crud.
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
Last edit: 09 Mar 2023 16:56 by Street Fighter LTD.
