And finally, Wookie's 82 begins !
Re: And finally, Wookie's 82 begins !
27 Nov 2024 13:25
Ever wished you had just stayed in bed !!!!!!!!!!!!!! I had a couple of days booked this week to try and get this frame finished so Monday came, a quick job on Mrs Wookie's car and then off to the garage. Fired up my trusty old welder and "what the f*~k" the wire speed control had gone down and it was spewing wire uncontrollably !!. Now this wasn't an expensive machine and I've had it for 25 years plus so I guess it's done ok. It wasn't in my plan to be replacing it right now but needs must so off to Amazon for a budget replacement (I say budget but $200 is still a chunk of change) In the meantime I stayed busy with some grinding and brazing. New machine arrived this morning so I whipped it out of the box, set it up thinking I could make up for lost time but when I connected the CO2 and opened the valve I could hear hissing even without the machine turned on - it should only pass gas when it's powered up and the trigger on the torch is pulled so that was short lived !!!!!!!!!!!!!! it's going back to Amazon tomorrow while I find an alternative replacement. Definitely not in my happy place right now
- Kelly E
27 Nov 2024 17:16
There's a difference between a cheap welder 20 years ago and a cheap welder today. My buddy and I pooled our money and bought a quality MIG welder 14 years ago and couldn't be happier. We've built a 12' flatbed trailer and a stack of other projects with great results.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
28 Nov 2024 00:01 - 28 Nov 2024 00:02Ain't that the truth, I would like something better but a month before Christmas and with no notice a better machine will need to waitThere's a difference between a cheap welder 20 years ago and a cheap welder today. My buddy and I pooled our money and bought a quality MIG welder 14 years ago and couldn't be happier. We've built a 12' flatbed trailer and a stack of other projects with great
Last edit: 28 Nov 2024 00:02 by Wookie58.
15 Dec 2024 09:31 - 15 Dec 2024 09:34
New welder is here and I'm back in business
(got to say for a cheap machine it does OK) I have managed to get the other side of the headstock finished and the "fixed" front engine mount. This side was a bit trickier as not been one to do things the "easy way" I wanted to run the hydraulic line for the clutch inside the frame tube but just chopping holes in the main structure didn't seem to be the best idea I've had !!! . At the outlet point on the lower tube I have reinforced the area around the hole with a piece of thick walled tubing, for the inlet I have added a piece of "slash cut" 12mm tube to reinforce and provide a guide for the hose. I have also added a "scallop" to allow the wiring a better route to the front connector station. Still moving forward
Last edit: 15 Dec 2024 09:34 by Wookie58.
The following user(s) said Thank You: Nessism, asphalt900, sf4t7
15 Dec 2024 15:42
Nice, and nice!
To my uneducated eye, the later year bikes have a much better reinforced headstock area, compared to the early 900/1000 frames. Good job cleaning up the factory welding, and building on that...
- sf4t7
15 Dec 2024 20:30
That's a clever way to hide the clutch line. Nice!
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
16 Dec 2024 00:03Thanks Ed, those brace pressings are certainly significant (2mm plate) and I think along with the additional tubing I have installed should allow me to "reap the benefit" of the improved suspension. I would say to anyone thinking of going this route with smoothing their frame that the key is to ensure you "add" enough material to be able to grind it back without "compromising the original structure".Nice, and nice!
16 Dec 2024 00:13Thanks Scotty, it's a "double bubble" as cosmetically it's cleaner but also keeps the line away from the heat of the header pipesThat's a clever way to hide the clutch line. Nice!
- rstnick
16 Dec 2024 17:09 - 17 Dec 2024 00:25Amazing work your doing on this bike Wookie!On another note, while looking around I noticed that the ZR750S (watercooled model) uses a very similar instrument cluster to the ZX6R that I had already (there are some small differences) I had a set turn up in the post as there are a few advantages (more realistic redline - fuel gauge) and they are cosmetically different. Side by side I am unsure but am angling towards the ZR unit - What do you guys think (ZX6R on the left)??
I wish I could Weld.
The Gauge clusters look very much like the 2005 z750s I have.
It's pick up is on the front sprocket.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 17 Dec 2024 00:25 by Wookie58.
17 Dec 2024 00:27It is indeed, this was a bit of a PITAIt's pick up is on the front sprocket.The Gauge clusters look very much like the 2005 z750s I have.
27 Dec 2024 15:19
So now the holiday's over I have been back at it today, I decided that I should break the neighbours back in gently so the welding and grinding can wait until tomorrow. I will be making my own loom using DTM style connectors but I still needed factory plugs for the instruments, ignition module/pulse-coils and speed sensor. I picked up a ZX9R loom a while back that had been butchered so was dirt cheap (I only needed the 16 pin plug for the instruments and the 3 pin for the speed sensor) I am using a GPZ1100A2 ignition system but fortunately several other kawas of that era use the same type igniter so have the same plug (I bought a GPX600 loom for $20 as it doesn't carry the "classic" premium of a GPZ part but is the same 10 pin plug). Having stripped both looms today I have harvested the required parts and have enough cable of the correct colours that I shouldn't need to buy much in the way of cable to build the full loom, a good day
30 Dec 2024 14:16 - 30 Dec 2024 14:32
Today has been a good day just a couple more days and the frame will be PC ready (I won't bore you with any more frame pics !) but also I have been thinking about my instruments. I am using ZX6R but there are a couple of issues, first it has a "temp" warning and obviously my bike is air cooled - 2nd is the 15k red line on the tacho. Just before Christmas I reached out to a company in Poland who make replacement faces to see if they would do a "one off" custom set. I sent them a drawing of what I wanted and got a response the next day saying "no problem" and that they would send me a preview after the holiday. Well today I got the preview and I am "stoked" - why can't other suppliers have this "can do" attitude, they are only charging $8 more than their off the shelf offering which is awesome. They have said 8-10 day turn around so I will post pics when they arrive and let you know about the finish etc (I have shared the "preview" below )
Last edit: 30 Dec 2024 14:32 by Wookie58.
The following user(s) said Thank You: sf4t7, howardhb, Quofan
