And finally, Wookie's 82 begins !
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Away
  • Moderator
  • Moderator
28 May 2022 12:21
#867807
So since my first post  at the back end of last year I have been feverishly clearing the backlog of jobs ( build bedroom furniture, Turbo blow up on my daily driver, yhada, yhada !) Finally I can get onto the bike. First job is to make some brackets for my lift. Space is an issue so a full table was out of the question  (and most of the budget options are rubbish) but I don't want to crawl around on the floor any more. I came across this single post screw lift, I had some reservations but the company that make them is only 30 minutes from me so I went over and checked it out before buying.
I chose not to have their mounts as I wanted to lift it in a specific way ( I want to be able to take it down to a bare frame but the frame still be securely bolted down, same when it goes back together) I have a very clear idea of what I want so hopefully my ambition won't exceed my ability (time will tell) wish me luck
  • Buzz Nichols
  • Buzz Nichols's Avatar
Re: And finally, Wookie's 82 begins !
28 May 2022 12:58
#867809
Following.
1978 KZ1000 LTD
  • ghostdive
  • ghostdive's Avatar
28 May 2022 13:45
#867815
Glad to see you getting started!
2001 ZX-6R
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
28 May 2022 14:28
#867821
Following your build. What brand of bike lift do you have and how high you can lift the bike?
  • MauiZ1
  • MauiZ1's Avatar
28 May 2022 14:48
#867823
Following
  • 750 R1
  • 750 R1's Avatar
28 May 2022 16:08
#867826
I do that all the time, gets the brain ticking over and you learn something new {hopefully} ....dive in !!!
  • Wookie58
  • Away
  • Moderator
  • Moderator
29 May 2022 00:31
#867846
Lift is a "Big Blue" from Quasar Products Ltd here in the UK, specs say 750mm full lift
The following user(s) said Thank You: Scirocco, JoeA
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
29 May 2022 06:40
#867854
Make us proud Wookie.
Nice and simple lift
Can you bolt it down to add stability.
Just thinking about during assemble and dismantling  the weight shift from center
 But I tend to over think everything
  • Mikaw
  • Mikaw's Avatar
29 May 2022 06:58
#867855
Count me in!
  • howardhb
  • howardhb's Avatar
  • God, I trust
29 May 2022 07:19
#867856
Watchin'
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
  • Wookie58
  • Away
  • Moderator
  • Moderator
29 May 2022 12:15
#867870
Thanks Dave I'll do my best - your words are still ringing in my ears from my introduction post when you made reference to how many projects never get finished
I will see how it goes with the lift and if I have any concerns I will add some "T" bars to the ends of the feet - however if you look at the below I think it will be more stable than you think
  • hardrockminer
  • hardrockminer's Avatar
29 May 2022 13:02
#867873
Is that an old Honda Pacific Coast?
