1981 LTD 1000 questions
  • Claude.
  • Claude.'s Avatar Topic Author
Re: 1981 LTD 1000 questions
30 Apr 2021 06:02 - 30 Apr 2021 06:02
#847748
Is this the mirror you are looking for ?
Pretty similar to what I’m looking for!! Curious that I did not see it when looking in Emgo catalog.
It is however different than OEM Kawasaki’s as there is no "ball joint" adjustment at the base of the mirror. I would prefer so as this ball adjuster allow "while-riding" adjustment.
But so far, it is the closest to what I’m looking for. Thanks!!!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
Last edit: 30 Apr 2021 06:02 by Claude..
  • TexasKZ
  • TexasKZ's Avatar
30 Apr 2021 19:18
#847792
Z1 Enterprises sells an assortment of mirrors that would work. I think some are period correct. Others are modern/cafe style.
I surfed through all their mirrors and the only "sililar" one is the Z1-R repro. Here, I’m looking for a 1981-1984 repro. Thanks anyway!
Edit: Geez! How to separate our post to the quote we are answering???
When you click to start typing your reply with quoted material, a red dashed line will appear at the very bottom of the text box. On the right end of the line is a red box. Click on it and your cursor will move outside the quotation area and you can type your post there, just like this.
The following user(s) said Thank You: Claude.
  • 750 R1
  • 750 R1's Avatar
30 Apr 2021 20:17 - 01 May 2021 04:22
#847797
The mirror link has disappeared, anyone know why ?
Never mind, it seems its back....weird
Last edit: 01 May 2021 04:22 by 750 R1.
  • Claude.
06 May 2021 08:52
#848088
One more question, related to every 1981-1984 KZ1000 & 1100 models.
Is there a way to make the camshafts end caps leak proof?
I had a 1981 KZ1100 from 1981 to 1996 and I remember pretty well the task of regularly cleaning the four "corners" of the cylinderhead to wipe off the oil.
Hopefully, the last 40 years provided a proven solution...
Thanks!!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
