1978 KZ650 Bike Build
Re: 1978 KZ650 Bike Build
06 Dec 2021 17:55
Looks good, what paint did you go with?
07 Dec 2021 04:33
Tremclad Hi Heat Semi Gloss. I need to go to a city to buy VHT. Will use it on the brake calipers.
07 Dec 2021 11:15
The Tremclad is a good match.
10 Dec 2021 19:27 - 10 Dec 2021 19:29
Running into a few hiccups. I put all the engine mounts in place except the rear upper. It's about a half diameter off the hole. Not sure why...all the other ones fit easily and there is no obvious damage to the frame.
I moved onto setting the timing. Everything went well but I need 5 shims that I don't have so I ordered parts to convert to shim over bucket. Waiting for them to arrive.
Still waiting for a new swingarm bolt so cannot work on the back end. That left the front end. It all went together quite well. The triple tree is from a Z1. The fender was a bit rusty but otherwise OK, and it cleaned up nicely with a bit of Mothers polish.
Last edit: 10 Dec 2021 19:29 by hardrockminer.
- Skidmark
11 Dec 2021 13:24
You may just need to rock the motor using the play in the other engine mounts to get that last bolt in.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
11 Dec 2021 16:10
I tried that...kept them all loose but it didn't work. So I drilled the hole in the mount a tad bigger.
01 Jan 2022 15:55
The swingarm bolt arrived but I need a bushing. The old one is frozen to the remaining bolt shaft. I found one on ebay and ordered. Should arrive in a couple of weeks. Not much that I can do without it so I decided to check out what the bike would look like when complete. It was a useful exercise as I discovered that my sidecovers for a B2 are not the same as a D1, which is the frame I'm working with. I have the right one but had to order a left one. I also discovered there is a difference in the tail piece....D1 frames are not made for one. So it will sit in the spares box for now.
- rstnick
06 Jan 2022 07:56
Coming along well.
The D side covers are taller in height, they come down lower in the triangle of the frame tubes.
One peg mount on the covers is in a different location too on one or both sides.
Some have managed to fit the tail to a D model 650.
The seats are different though, to allow the tail to fit behind.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
19 Jan 2022 12:19
The bushing arrived and the swingarm is now properly installed. While waiting I began working on wiring. The main harness had been unwrapped so I was left with a bit of spaghetti to figure out. I have the front of the bike done but am having a bit of trouble with the other end. Could someone show a couple of photos of how the harness attaches to the frame under the tank and near the battery box?
- rstnick
23 Jan 2022 07:38
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: hardrockminer
23 Jan 2022 12:47
Thanks Ron. They were very helpful, although I have both flasher units on the left site. (This is a D1). But he right side photo was very useful.
I've been working on wiring for a couple of days now. The headlight, brake lights, signals and horn are all operating correctly now.
25 Jan 2022 13:17
The Coquihalla highway is finally open again after last November's rain storms, so I drove down to Chilliwack to my favourite Vapour Blaster for a little engine cleaning. It always amazes me how a thorough cleaning can make an engine look new again! This engine won't go into the rebuild project, as I already had one ready to go.
