1976 Kz 900 A4
Re: 1976 Kz 900 A4
28 Jul 2020 05:10
I checked on another forum where I saw photos of 91006 S/N without the oil capacity. So the change occurred after that point.
Re: 1976 Kz 900 A4
05 Aug 2020 15:56
Well after several calls and threatening to come get my parts finished or not, the guy finally polished the lowers. The front calipers and bracket arrived Monday from vapor hone so hopefully I’ll have the front end complement this weekend...
- Kaylinator
Re: 1976 Kz 900 A4
05 Aug 2020 20:19
Those forks came out nice! Wish mine came out that good...
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ400-B1
2022 Z900RS SE
Re: 1976 Kz 900 A4
06 Aug 2020 17:41 - 06 Aug 2020 18:18
I need help sizing a split pin aka roll pin. I don’t now if you order the pin to the hole ID, and the friction fit is factored in. Need help. Or maybe someone can help me and give me the size. It’s the roll pin that indexes a top cap to the inner damper of the front fork. Also can anyone help source the phonolic ring at the top of the attached photo.
EDIT
Found the damper piston rings.
z-fever.de/shop/en/product_info.php?info...gs--fork-2piece.html
EDIT
Last edit: 06 Aug 2020 18:18 by Mikaw.
Re: 1976 Kz 900 A4
06 Aug 2020 17:44
- Skidmark
Re: 1976 Kz 900 A4
06 Aug 2020 18:58
Roll pins come in compressed sizes. IE - a hole 1/8" diameter would use a 1/8" roll pin. The compressed size should be factored into the pin.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Re: 1976 Kz 900 A4
07 Aug 2020 07:38Skidmark wrote: Roll pins come in compressed sizes. IE - a hole 1/8" diameter would use a 1/8" roll pin. The compressed size should be factored into the pin.
Thank you. Obviously no way to get a digital caliper to measure the hole. I do have a letter and fractional drill bit set I can use to determine the hole ID.
Re: 1976 Kz 900 A4
08 Aug 2020 18:25
Not the best composition but calipers are painted... they turned out nice. Vapor hone before paint is well worth it
Re: 1976 Kz 900 A4
09 Aug 2020 15:47 - 09 Aug 2020 15:48
Probably something no one would ever notice but just the level of detail I want to get to on this build. I didn’t like the dull finish the vapor hone left so I polished the exposed recess for the caliper bolt spacers and the pad B metal retaining washer live. But doing so I boogered up the paint. VHT can says after 1 hour if additional coats are needed you must wait 7 days. Well I know what I’ll be doing next Sunday.
Last edit: 09 Aug 2020 15:48 by Mikaw.
Re: 1976 Kz 900 A4
13 Aug 2020 15:58
Well I’m feeling Skidmarks pain. I can’t catch a break. Messing up the fresh caliper paint started it. Maybe it was the four weeks I waited for the front forks but something has started a rough spot. So I’m seriously disappointed in the fork polish job. I got them out in the sun today and yuck. What a crappy job, I was so looking forward to getting them assembled today. So the are packaged up and off to a second guy for a repolish. He’s only charging me $20 but it’s more down time. I’m taking advantage and sending him the rear sprocket carrier, the points cover and clutch cover. Let’s hope this time I get timely tur around and a better job.
- Skidmark
Re: 1976 Kz 900 A4
13 Aug 2020 16:00
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Re: 1976 Kz 900 A4
13 Aug 2020 16:02
Still having trouble finding the correct roll pin for the top cap on the fork inner damper. I measured and came up with 3 x 20 mm. I stopped at a small engine repair shop and bought a couple. And to help my chances I bought a couple 1/8” x 1” and both are to big. Tomorrow I’ll try again.
