1976 Kz 900 A4
- Dragbike_Mike
Re: 1976 Kz 900 A4
04 Jul 2021 05:17
Matt - to my eyes, those wristpins do indeed look galled. Unfortunately, I don't know of an "easy" fix. Back in the day, the right thing to do when prepping a (race) crank was to have the small ends of the rods bushed with a silicon bronze material. This eliminates the potential for galling. The downside is that the crank has to be disassembled in order to do this. Falicon would do this as part of their stock rod prep/strengthening service. I don't know if Falicon is still in business. Maybe some other forum members can chime in with other suggestions. Hope this helps!
Mike
Mike
Re: 1976 Kz 900 A4
04 Jul 2021 07:33
Thanks Mike,
What I don’t know is, are the pins sacrificial and the rods might be ok.
- Dragbike_Mike
Re: 1976 Kz 900 A4
04 Jul 2021 13:06
I wouldn't necessarily view the wristpins as being sacrificial. The interface between the wristpin and rod bore is, in essence, a plain bearing. So, they're always separated by that thin layer of oil and should never make contact with each other. Because of the previous galling, there might be high spots (ridges) in that pin bore that would break through the oil layer on the next go around; putting you back to square one with more galling.
If you can finely polish that wristpin bore to remove those peaks, without affecting the overall bore diameter, then you "might" be okay, beings that this is a street motor using stock pistons turning reasonable RPM levels and lubricated with good, modern-spec oil. If you were building a race-spec motor slinging heavy pistons at high RPMs, then all bets would be off.
This is just my opinion and should be treated as such. As mentioned before, there might be other forum members with more experience with rebuilding stock, street-type motors that could give their insights and opinions.
Mike
Mike
Re: 1976 Kz 900 A4
04 Jul 2021 13:13
Thanks Mike,
Anyone else have an opinion or procedure to share.
- krazee1
Re: 1976 Kz 900 A4
04 Jul 2021 13:57
FWIW, I would agree with Dragbike Mike on all accounts.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Re: 1976 Kz 900 A4
04 Jul 2021 14:29 - 04 Jul 2021 14:30
You might want to think about another crankshaft. Maybe the oinkster has one. Or one of the members? There are a few on ebay but who knows what condition?
Last edit: 04 Jul 2021 14:30 by hardrockminer.
Re: 1976 Kz 900 A4
04 Jul 2021 14:57 - 04 Jul 2021 14:58Ouch. Hope I’m not going there.You might want to think about another crankshaft. Maybe the oinkster has one. Or one of the members? There are a few on ebay but who knows what condition?
Last edit: 04 Jul 2021 14:58 by Mikaw.
- Skidmark
Re: 1976 Kz 900 A4
04 Jul 2021 20:50
I would not use them that way. Inspect the upper rod bearings those wrist pins cam out of very thoroughly before using them.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Re: 1976 Kz 900 A4
05 Jul 2021 08:32
I found the specifications for the pin and rod small end. The pins are definitely trash. Worn down below spec. I don’t have any bore gauges to check small ends. The guy that is welding up my head is an engine machine shop, I’m going to run the crank over to him this week and have him spec it out. Fingers crossed! I did find two crankshaft specialist close, if it’s out of spec I’ll take it to them for ideas.
Thanks all.
Thanks all.
Re: 1976 Kz 900 A4
07 Jul 2021 16:18
I was referred to these guys
www.facebook.com/Gardnerracingconcepts
as a good Kz crankshaft place. I wasn’t sure based on their FaceBook page. I messaged them and they replied. “ yes we can help we work on those daily and would love to work with you on your project” going to follow up with some phone conversations and see where it goes. Anyone know these guys?
- DOHC
- Those Doe-Hawks really go!
Re: 1976 Kz 900 A4
07 Jul 2021 20:28I've never done business with them, but they are often the highest and most recommended place on this site when this question has been asked. And most comments suggest that's it's one of the last crank shops that still does good work.I was referred to these guys www.facebook.com/Gardnerracingconcepts as a good Kz crankshaft place..... Anyone know these guys?.
hstrial-gcranks.homestead.com/About-Us.html
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Re: 1976 Kz 900 A4
08 Jul 2021 05:06I've never done business with them, but they are often the highest and most recommended place on this site when this question has been asked. And most comments suggest that's it's one of the last crank shops that still does good work.I was referred to these guys www.facebook.com/Gardnerracingconcepts as a good Kz crankshaft place..... Anyone know these guys?.
I don't have any personal experience with Gardner but they come highly recommended.
This quote is from the GS Resources resident go-fast drag bike engine builder Ray Rains...
Quote rapidray:
For roller bearing cranks, the ONLY places I will send one is to John Pearson in Ohio, Stan Gardner in Maine, or Bob Mosher in Florida. I wouldn't ask Falicon what time of day it is!
Ray.
