KZ650 Restoration
Re: KZ650 Restoration
25 Jun 2020 05:25
If you've never done a frame up resto I would offer the following advice.
1) Take lots of photos of what things looked like before you remove any particular part. They are useful when you want to put things back together again.
2) Buy a box of baggies and a roll of freezer tape to label the bags and put things into them in some sense of order. That way you will have everything to put things back together again...nothing worse than looking for that one part that disappeared and is absolutely necessary for the rebuild.
3) Download a correct manual for your bike. It will have a section on assembly/disassembly. Follow it carefully. It will have another section on maintenance. Read it thoroughly.
4) Buy a couple of torque wrenches. One for inch pounds....1 to 150 and one for foot pounds...15 to 150. The manual will have a section on proper torques and sequences for bolts. Follow it.
Lastly, set up a rebuild post here and post photos and comments on your progress. Some of the best Kawasaki enthusiasts in the world are on this site and will be an invaluable resource when you get stuck.
Good luck!
Good luck!
25 Jun 2020 06:20
....and use JIS (Japanese Industrial Standard) screwdriver tips NOT Phillips or you will be sorry. If you need more info on JIS just ask. Ed
- calum
25 Jun 2020 06:44
Looks like a solid basis for a restoration.
All good advice here. I would like to add that I went the second route on my restoration and completely stripped the bike down restoring or replacing everything that was past the service limit, rusty or just not up to my standards. It took me a year of weekends with no other real commitments. It also ate through my savings like you wouldn't believe. The most expensive things were specialised tools and getting the chrome redone on some parts that are no longer available new.
I you do go this route, be prepared to spend some money on parts and tools otherwise the project will stall. If that happens, well... just see Ed's previous post
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
25 Jun 2020 07:36
I love that statement... “ran great before it was parked” all that is is a buyer beware alert...
