The rusty hulk
Re: The rusty hulk
24 Jun 2021 10:01Still building up confidence. Wish I was there. Looking good.
- 73z1
Re: The rusty hulk
26 Jun 2021 05:06Thanks for the note.Still building up confidence. Wish I was there. Looking good.
- 73z1
The following user(s) said Thank You: KZJOE900
Re: The rusty hulk
26 Jun 2021 14:07 - 26 Jun 2021 14:11
Are you going to shave the side fins down to aluminum?
Mikaw, you're over thinking this. It's not the end of the world if you do something incorrectly and have to split cases again. When I was working with one of my Z1B's I had to tear the engine down five times trying to figure out why the kick shaft was making grinding noises when the engine turned over. Turns out it was because the transmission wasn't standard. The muscles in my shoulders were very tired from all the shrugging!
Last edit: 26 Jun 2021 14:11 by hardrockminer.
- 73z1
Re: The rusty hulk
30 Jun 2021 05:35I will sand head fins when complete.Are you going to shave the side fins down to aluminum?
- 73z1
Re: The rusty hulk
30 Jun 2021 11:39
Getting close! Do you plan to re-paint the DOHC on the stator and points covers?
- 73z1
Re: The rusty hulk
02 Jul 2021 04:40I replaced the alternator cover after photo.Do you plan to re-paint the DOHC on the stator and points covers?
- 73z1
- slmjim+Z1BEBE
Re: The rusty hulk
03 Jul 2021 05:58
The point at which a Z1 in the midst of a frame-off starts to look like a Z1 again is one of the most satisfying experiences in the entire process. Lookin' good.
It's interesting to observe other enthusiasts techniques and order of reassembly. If we were into the top end at all, we always opt to install the motor sans jugs & head to lighten the load.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- 73z1
Re: The rusty hulk
03 Jul 2021 08:13I lay engine on side and put frame on engine, frame is much lighter, I have a thick points cover.It's interesting to observe other enthusiasts techniques and order of reassembly. If we were into the top end at all, we always opt to install the motor sans jugs & head to lighten the load.
CB750 photo.
- 73z1
