1974 kz trike 15 Jan 2020 09:02 #817129
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
really digging your project!
love how it's coming out ,
keep us posted.
The following user(s) said Thank You: Shankkole
1974 kz trike 16 Jan 2020 05:05 #817181
  • Shankkole
  • Shankkole's Avatar Topic Author
  • Thank you received: 141
The reproduction caddy lights look great, even taped on. I have some fun options in the works, we shall see if this thing goes to insane level.works busy this week but hope to finish tub by the weekend.
1974 kz trike 16 Jan 2020 21:42 #817237
  • Shankkole
bottom of tub roughed after cleaning.
1974 kz trike 16 Jan 2020 21:51 #817238
  • Shankkole
Top of the seat tub laid.
1974 kz trike 17 Jan 2020 09:01 #817259
  • Shankkole
The plywood forms are removed, seat/trunk cut out, along with side doors .
1974 kz trike 17 Jan 2020 18:36 #817320
  • irishwill
  • irishwill's Avatar
  • Thank you received: 6
gonna be killer bud!
1974 kz trike 21 Jan 2020 14:11 #817562
  • Shankkole
I got the outside ready for body filler. Since 2nd jumped out on the test ride I looked into trans parts and just ordered a MRE undercut trans with the orient billet 2nd gear for pulling those fat mickeys.Really good guy communication from that crew !
1974 kz trike 22 Jan 2020 09:47 #817608
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
TexasKZ wrote: Nice work straightening the mouth of that carb.
I wonder what the dude was thinking when he installed the rear end upside down?? :silly:
It's been a while but the chain opening on the rear end isn't centered as I recall, so if the drive sprocket was on the wrong side the only thing you could do was flip the rear axle housing to get it on the proper side. I thought there was a negative to doing that but I can't recall what it was now and it's not that the drain plug is on the top.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
1974 kz trike 22 Jan 2020 15:21 #817636
  • Shankkole
So the rearend was designed with the chain on the right on the o.g. harley servi trans. To adapt it to fit this they simply flipped it over for the offset to work with the kaws offset for standard left side chain operation( when I pull apart we shall see if some sprocket shimming was done ). I am planning on making some fiberglass bolt on covers but honestly its made to run open, just not exposed. after cleaning I found some weep holes but they need to be improved as well.The rear will be two weeks of after work to get right I'm guessing now.
1974 kz trike 27 Jan 2020 18:47 #818066
  • Shankkole
I used rage filler before blocking it out.rolled on a resin coat.I hope to primer later tonight.
Last edit: by Shankkole.
1974 kz trike 28 Jan 2020 06:38 #818084
  • Rick H.
  • Rick H.'s Avatar
There used to be an old motorcycle shop in Milwaukee that catered only to working on Harleys. I seem to remember them working on some type of conversion using a Servi Car rear end and as part of the process they literally just flipped the rear end over to accommodate the left side drive sprocket. I don't have a Servi Car to look at but I think the chain ran on the right side of the trans and the offset was created by having unequal length rear axle tubes. The left side was longer, right was shorter. This centered the chain in the opening on the differential case. This was all a very long time ago and I could be mistaken on what they were trying to accomplish. There was some roadblock that they ran into when they did this but I can't recall what it was. The project didn't really interest me at the time so I didn't pay much attention to it. Sorry...
Rick H.
Rick H.
1974 kz trike 28 Jan 2020 20:48 #818148
  • Shankkole
primer on.
