Saving a '81 KZ750-E
  • Skidmark
  • Skidmark's Avatar Topic Author
Re: Saving a '81 KZ750-E
12 Jan 2021 19:01
#841613
I did order a couple, made sure the ship address was correct, so we will see when they arrive. As much as I appreciate the favor, I rarely accept, or ask for, one twice. A guy has to have some standards to live by...
It dawned on my that once I get the head back on, I will by able to test fit the exhaust. Talk about an appearance change! I have had that brand new Delkovic header in the box for over a year now. Never assembled. I am sure once it is installed it will fire up the motivation! I should get around to ordering some new coils / wires soon as well.
Retired gearhead
'81 KZ-750 E2
  • Kaylinator
  • Kaylinator's Avatar
12 Jan 2021 20:41
#841619
Skidmark wrote: Tinkered on the bike for a while today, but it all seems to be "invisible" work. No real changes in appearance. I cut my chain to length, and riveted the master link on. Adjusted the chain tension and torqued the rear axle. Finished with all of the engine mount bolts - a couple had to be hand ground since the same size bolts I could only find with bigger hex heads. All of the motor mounts are torqued now. Filled and bled the rear brakes, and torqued the counter shaft sprocket nut. Sometimes you can tinker for hours and step back and say you got a lot done, but none of it shows!
This is the title of my autobiography.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • Skidmark
14 Jan 2021 22:05
#841718
Tomorrow I am getting the NPT plugs to block off the fresh air passages. As soon as those are tapped and installed I should be able to install the cylinder head. The last two shim should be arriving any day (says the ultimate optimist!).
Retired gearhead
'81 KZ-750 E2
  • Skidmark
15 Jan 2021 15:56
#841751
I finally got around to unwrapping my Delkevic header. I am pretty impressed with the quality of manufacture, and the welding looks top notch. Most likely robotic from the extreme consistency. The company I worked for had a Panasonic robotic welder, but it was a MIG. I'm getting excited to see this exhaust on the bike!
Retired gearhead
'81 KZ-750 E2
  • Mikaw
  • Mikaw's Avatar
15 Jan 2021 17:28
#841754
Skidmark wrote: I finally got around to unwrapping my Delkevic header. I am pretty impressed with the quality of manufacture, and the welding looks top notch. Most likely robotic from the extreme consistency. The company I worked for had a Panasonic robotic welder, but it was a MIG. I'm getting excited to see this exhaust on the bike!
I’d be excited too. That thing is nice. I bet it will look great installed
  • Skidmark
15 Jan 2021 18:19
#841759
Retired gearhead
'81 KZ-750 E2
  • Skidmark
15 Jan 2021 18:25 - 15 Jan 2021 18:31
#841760
I am using a 1/8-27 NPT plugs to block the fresh air ports in the head. The holes the factory drilled into the head are the exact size for this thread, which meant no drilling.
Retired gearhead
'81 KZ-750 E2
Last edit: 15 Jan 2021 18:31 by Skidmark.
  • Skidmark
15 Jan 2021 18:33
#841762
Mikaw wrote:
I’d be excited too. That thing is nice. I bet it will look great installed[/quote]
I am hoping for an upswing more than parallel to the road. If it mounts too parallel to the road I may modify it and have it welded at the angle I like.
Retired gearhead
'81 KZ-750 E2
  • Skidmark
15 Jan 2021 19:01
#841765
Nice logo etched into the stainless muffler. No metal stickers, or riveted name plates.
Retired gearhead
'81 KZ-750 E2
  • Kaylinator
15 Jan 2021 19:25
#841767
I'm sure you'll love it. I'm very happy with mine. Shouldn't be anywhere near parallel to the road if it's anything like mine. Clears above the rear axle.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
  • calum
  • calum's Avatar
16 Jan 2021 02:39
#841778
This is what it looks like mounted to the stock footrest brackets. There's a bit of leway to mount it higher, but not much or the pipes won't seal at the head.
  • calum
  • calum's Avatar
16 Jan 2021 02:43
#841779
Here's how the shorter "classic straight" muffler looks:
The following user(s) said Thank You: DOHC, Skidmark
