Saving a '81 KZ750-E
  • Skidmark
  • Skidmark's Avatar Topic Author
Re: Saving a '81 KZ750-E
09 Jun 2020 12:45 - 09 Jun 2020 12:47
#827694
So since I was in town, I dropped by the paint shop to take some progress pictures (since I forgot last time!). He was just calling me when I walked in to tell me it was all ready!
Retired gearhead
'81 KZ-750 E2
Last edit: 09 Jun 2020 12:47 by Skidmark. Reason: Forgot attachment
  • Skidmark
09 Jun 2020 12:57
#827695
Since this is a picture, I guess it happened!! This is the first loose fit of the bodywork. I like it!! :woohoo:
Retired gearhead
'81 KZ-750 E2
  • calum
  • calum's Avatar
09 Jun 2020 13:07
#827697
Looking good!! :woohoo:
That will look nice with a black motor.
  • Mikaw
  • Mikaw's Avatar
09 Jun 2020 17:37
#827713
Your right “it happened”! And very well at that.
As far as vapor blasting it high pressure water with a sand slurry mixture. No Temperature involved. If you can find someone to vapor blast your cases you will be amazed at the finish. It’s also called vapor honing
  • Skidmark
10 Jun 2020 13:36
#827777
Emblems made more difference than I thought they would.
Retired gearhead
'81 KZ-750 E2
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
10 Jun 2020 14:16
#827787
Your bike rebuild is the next upcoming BOTM :woohoo: :woohoo: :woohoo: :woohoo:
Love the lime color sheme, calum is right, a satin black gloss colored engine is the way you have to go.
  • Skidmark
10 Jun 2020 14:56
#827791
The plan is all black, with some cylinder head fins filed, and the text on the valve cover and side case covers sanded as well. Just the highlights that make sense.
Retired gearhead
'81 KZ-750 E2
  • Skidmark
12 Jun 2020 15:56
#828010
I got the top case back from the hot dip tank. Definitely took care of all the oil residue. As far as cleaning the painted surfaces, not so much...
Now comes all the single sided razor blade work to get the block gasket off. Wish my fingers luck! The bottom case will be ready Monday. I'm still ordrring the last few bearings and bushings. It will take some time getting the painted surfaces prepped anyway.
Retired gearhead
'81 KZ-750 E2
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Jun 2020 16:07
#828013
Don´t forget to give all oil ports and main gallery a very good clean!!!
  • Skidmark
12 Jun 2020 19:57
#828026
The easy side is done.
The outside is going to need a lot of work before it's ready for paint.
Retired gearhead
'81 KZ-750 E2
  • calum
  • calum's Avatar
13 Jun 2020 02:11
#828039
Don't loose that mounting bolt! Can be hard to come by (at least over here).
  • Mikaw
  • Mikaw's Avatar
13 Jun 2020 08:59
#828054
If you can find someone to glass bead blast it would be worth the money in the time savings. It or vapor blasting result in a great surface to start with.
