1982 KZ750N build
- JohnLuke
- 1982 KZ750N Spectre
Re: 1982 KZ750N build
31 Oct 2018 15:33
Lol I’m sure he did. I just took it home to clean it out. When I reassembled it I must have not put it together correctly.
31 Oct 2018 16:17
A write up of the valve shims positions and thickness for later adjustment is a must do.
- JohnLuke
31 Oct 2018 16:52
Yeah. He did do that for me. I just can’t find the piece of paper he did it on.
I could be wrong but could I take the shim where there is two much clearance and put it in my tight number 1 cylinder. Thus hopefully balancing it out. Does that sound logical.
Thanks!
Thanks!
31 Oct 2018 17:08JohnLuke wrote: ..............I could be wrong but could I take the shim where there is two much clearance and put it in my tight number 1 cylinder. Thus hopefully balancing it out. Does that sound logical. Thanks!
No, it does not sound at all logical. It sounds like you are just trying to avoid measuring the clearances and properly adjusting them. Keep in mind that if you do not adjust the clearances properly (see the Kawasaki Service Manual for details) you stand a good chance of damaging the engine rather than improving it. Ed
- JohnLuke
31 Oct 2018 17:24
Oh okay! I don’t mind checking clearences. I was just curious as to the best method to find out which shim was placed incorrectly.
Thanks!
Thanks!
31 Oct 2018 18:32JohnLuke wrote: Oh okay! I don’t mind checking clearences. I was just curious as to the best method to find out which shim was placed incorrectly.
Thanks!
Measuring the clearances is the only way to see if any of the clearances are not within spec. If a wrong shim was inserted measuring the clearances should identify the problem. Ed
- BobberDan
01 Sep 2020 18:32
Good eye on the stems...just installed 82750n1 on my 79 kz750b
- BobberDan
01 Sep 2020 18:44
rich mixture is cool..lean is hot...i have read several posts with same problem with no solution...Mikuni carbs dont have a choke.....what about a malfunction in the cold start passages?????
01 Sep 2020 19:54
No offense intended, but is there a reason you are replying to issues that are about 2 years old? Ed
- BobberDan
01 Sep 2020 20:07
2 good reasons...
#1. Not paying attention.
#2 Good weed
#2 Good weed
