1982 KZ750N build 30 Oct 2018 15:51 #793114
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
  • Thank you received: 5
I really don’t know if aftermarket ones where used.
1982 KZ750N build 31 Oct 2018 08:46 #793160
  • JohnLuke
Would this explain why it’s having trouble starting, running and reving?
Lol I think I found out why it’s so freaking hard to start and why there is excessive gas in the pod on carb #1. And why every once in a while it would back fire though carb #1. I checked the compression in cylinder #1 and almost all of it is going out #1. Meaning I took the plug out and used compressed air. My guess is maybe I put the valve shims in wrong or something. Cuz I’m pretty sure the valve isn’t bent. I had a professional do my valves. So I guess I’ll need to take the cover and cams off to see what’s up. I really hope I don’t have to take the head off cuz I don’t want to pay the money for a new gasket right now.
Thanks!
1982 KZ750N build 31 Oct 2018 15:03 #793181
  • JohnLuke
I just checked and it would seem I accidentally put the wrong shim in cylinder #1. There is absolutely no clearance. So I’ll dig in later to see what shim is in it. I had them done professionally by a dude and when I got it back I took everything apart and cleaned them. Put it back together wrong I guess.
Thanks!
1982 KZ750N build 31 Oct 2018 15:25 #793184
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
A real professionally mechanic should re-check his valve Job twice, before and after!!!
The following user(s) said Thank You: gordone, JohnLuke
Last edit: by Scirocco.
1982 KZ750N build 31 Oct 2018 15:33 #793186
  • JohnLuke
Lol I’m sure he did. I just took it home to clean it out. When I reassembled it I must have not put it together correctly.
1982 KZ750N build 31 Oct 2018 16:17 #793189
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
A write up of the valve shims positions and thickness for later adjustment is a must do.
1982 KZ750N build 31 Oct 2018 16:52 #793191
  • JohnLuke
Yeah. He did do that for me. I just can’t find the piece of paper he did it on.:angry:
I could be wrong but could I take the shim where there is two much clearance and put it in my tight number 1 cylinder. Thus hopefully balancing it out. Does that sound logical.
Thanks!
1982 KZ750N build 31 Oct 2018 17:08 #793193
  • Thank you received: 2829
JohnLuke wrote: ..............I could be wrong but could I take the shim where there is two much clearance and put it in my tight number 1 cylinder. Thus hopefully balancing it out. Does that sound logical. Thanks!
No, it does not sound at all logical. It sounds like you are just trying to avoid measuring the clearances and properly adjusting them. Keep in mind that if you do not adjust the clearances properly (see the Kawasaki Service Manual for details) you stand a good chance of damaging the engine rather than improving it. Ed
1982 KZ750N build 31 Oct 2018 17:24 #793195
  • JohnLuke
Oh okay! I don’t mind checking clearences. I was just curious as to the best method to find out which shim was placed incorrectly.
Thanks!
1982 KZ750N build 31 Oct 2018 18:32 #793199
JohnLuke wrote: Oh okay! I don’t mind checking clearences. I was just curious as to the best method to find out which shim was placed incorrectly.
Thanks!
Measuring the clearances is the only way to see if any of the clearances are not within spec. If a wrong shim was inserted measuring the clearances should identify the problem. Ed
1982 KZ750N build 01 Sep 2020 18:32 #834182
  • BobberDan
  • BobberDan's Avatar
  • Thank you received: 0
Good eye on the stems...just installed 82750n1 on my 79 kz750b
1982 KZ750N build 01 Sep 2020 18:44 #834184
  • BobberDan
rich mixture is cool..lean is hot...i have read several posts with same problem with no solution...Mikuni carbs dont have a choke.....what about a malfunction in the cold start passages?????
