Wakt out KZ1000 13 Oct 2018 19:28 #792271
  • KZ802
  • KZ802's Avatar
  • Thank you received: 13
Very cool build. I'm watching intently. That bike how you found it is a weird combination of very stock stuff that most bikes this age don't have anymore, and just plain different stuff that I've never seen. Wakt out definitely fits it. Please keep the stock paint you never see those. And proceed and post pictures, I can't wait to see what you do. so far so good
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
The following user(s) said Thank You: waktaylor
Wakt out KZ1000 13 Oct 2018 21:05 #792272
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I see why you wanted a new one!
Wakt out KZ1000 13 Oct 2018 22:30 #792275
  • waktaylor
  • waktaylor's Avatar Topic Author
  • Thank you received: 9
Thanks fellas.
Yea this bike has a strange last. I’m guessing the exhaust is aftermarket. I think redline sells the same one.
More in store shortly. I’ve been working out of town a lot lately but I’m sort of obsessing over getting this bike right.
I’m certainly keeping the original color. I’m thinking black side covers tho since I need the right side.
Wakt out KZ1000 14 Oct 2018 11:40 #792299
  • waktaylor
Removed the bent garbage fork today. Also went a little nuts with the cut off wheel. modified rear fender. removed passenger pegs. Bandit swing arm hits them.
More pics to come this afternoon.
Wakt out KZ1000 15 Oct 2018 10:31 #792330
  • waktaylor
This engine must have ran like shit all the way till it didn't.
#2 rings were so stuck i had to pull the wrist pin, leave the piston in the cylinder and remove the entire assembly. Then hammer the piston out.
Too bad I also broke off the mounting boss for the missing timing chain guide rail :(
Looking for a "new" cylinder set.
Kyle
Wakt out KZ1000 15 Oct 2018 18:01 #792345
  • waktaylor
Cleaned the block/transmission and liberally applied Por-15. now NONE of the screws will be removable. This shit is like metal when it dries. Not what I was going for.. minor mistake
Last edit: by waktaylor.
Wakt out KZ1000 15 Oct 2018 21:08 #792353
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
NONE of the screws will be removable......
I really hope that the clutch springs that have been compressed for the last 40 years are not shot, or that the clutch plates are not badly worn, or that there are no bent shift forks, or bad transmission gears or bearings, or broken parts of the missing chain tensioner in there, or scum clogging the oil pump screen, or ..........................
Wakt out KZ1000 16 Oct 2018 04:57 #792357
  • waktaylor
I have had the covers off so the screws will come out with a little work. I should have done this properly and taken apart the engine. Wont do it again, i promise.
Wakt out KZ1000 19 Oct 2018 10:00 #792546
  • waktaylor
Can you spot all the non kawa parts?
Wakt out KZ1000 19 Oct 2018 15:18 #792564
  • waktaylor
Test fitting most of the parts today
Wakt out KZ1000 21 Oct 2018 01:12 #792630
  • gordone
  • gordone's Avatar
  • Thank you received: 67
Looking good!
Project:
Wakt out KZ1000 21 Oct 2018 18:28 #792664
  • waktaylor
Now on to color choices. I wanted to go with the Ducati red but my lady loves the Kawasaki deep blue. I’m not a purist as is obvious so I may use a custom color.
