Big Mikey's 1974 Kawasaki Z1-A
  • TexasKZ
  • TexasKZ's Avatar
Re: Big Mikey's 1974 Kawasaki Z1-A
20 Dec 2017 18:00
#776438
Who made the exhaust system?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
20 Dec 2017 22:31 - 20 Dec 2017 22:45
#776446
I love the hand bend curved Titan header style too
www.bulldock.jp/parts/win_mccoy/#neo
Michael
Last edit: 20 Dec 2017 22:45 by Scirocco.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
22 Dec 2017 05:18
#776481
Hi Big Mikey,
That's a great build, and an inspiration. We've been contemplating building a Z-bike street sleeper/hotrod. We just have to make room for another bike somehow without hogging or blocking access to our homegrown service bay.
Good Ridin,
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • M_a_t_t
  • M_a_t_t's Avatar
22 Dec 2017 19:27
#776522
Is the engine powder coated? If so was it assembled or did you get each part done individually?
Thanks
Matt
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • Big Mikey
  • Big Mikey's Avatar Topic Author
02 Jan 2018 20:27 - 02 Jan 2018 20:28
#776840
@Kidkawie
I used a 2003 zx6r swingarm. There's a ton of really good information on this forum for using that swingarm. Old Man Rock has a nice PDF as a how-to within the files on KZrider main-site. I reached out to Leon for help on the pivot portion of my swingarm, and he did a kick-ass job.
High-level of what needs to be done: Pivot needs to be modified to accept stock Z1 bolt / If you go dual rear shocks, the rear caliper needs a new or modified mount / Mounts need to be created for shock(s) / Offset front sprocket to keep chain aligned / If you keep the cable clutch (as opposed to hydraulic), the clutch cover needs some modification to the backside to avoid hitting the new offset front sprocket and chain / Depending on your clearances, may also need to make a guide, roller or both for the chain to avoid damage to chain, frame, engine case or swingarm
@TexasKZ
See Scirocco's post :)
@Slmjim + Z1BEBE
Thank you! You should bite the bullet and do it! Was a ton of fun :) .... but time consuming and expensive
@M_a_t_t
I painted the engine with a ceramic coating. I decided to go with Cerakote ( www.cerakotehightemp.com ) and went with one of their Air Cure products. I did some of the loose covers individually and did the rest of the engine lightly assembled (without internals). There is a photo in my earlier post showing the engine lightly assembled. We will see how well the coating holds up to wear and tear...
Last edit: 02 Jan 2018 20:28 by Big Mikey.
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
15 Jan 2018 20:40
#777319
Awesome and stunning Mikey. One of the best builds I've seen, EVER.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Jan 2018 14:22
#777657
it turned out very nice.
thanks for the kind words,
i'm always happy to help on such a cool project.
