Wow, what a great discussion. Thanks to everyone for contributing. I have a lot better understanding now.
What I did: Removed the MC and disassembled. Kicked myself for discarding the original piston. Acquired a second MC from the donor of the bike. It was frozen solid. Tried freeing it with penetrating oil, no good. Soaked it in Evaporust for 2 days, scrubbed it with soap and hot water. Repeated penetrating oil, with success. Compared the OEM and K&L pistons, visually and measuring with vernier caliper. They were within a few hundredths of a mm of each other. According to the specs in a Kaw. service manual, both pistons were slightly undersize, and the rubber cups barely large enough. Took a comparison pic exactly like DOHC's. Came to the conclusion that the Z1R MC is just a bitch to bleed, and the K&L piston was not the problem. But I did use my friend's MC with its OEM piston and seals, which looked great after cleaning. Its long, frozen slumber did not appear to have harmed it.
I repeated the vacuum bleeding process. This time I dismounted the calipers and pushed the pistons back by hand. A little air bubbled into the reservoir. I remounted them and continued and began to get a firm lever. I quit for the day since I was tired, forgetting the tying off the lever trick. The next day, my mechanic friend said that trick only needs a couple hours to work. I did a little more vac. bleeding, which made further improvement, then tied the lever back for about 3 hours. It did help, but not dramatically. I now have a nice firm lever, yay!
One slight problem remains. With both calipers torqued in place, observing closely while pumping the lever, one glides evenly back and forth, but the other kind of wiggles, like it's hanging up a little on one of the bolts. I did polish slight corrosion off all the bolts and grease them and the o-rings and dust covers lightly.
Not a big worry. I bet the issue will resolve itself with some mileage.
Let me offer this for opinions: The design of the Z1R MC is odd, with a "dead zone" of cylinder beyond the outlets. Usually, a cylinder dumps out a single outlet on the back wall. This one has 2 outlets in the side wall, before the end. My theory is that air can get trapped there, beyond the outlets.
Another reason for bleeding woes, in my case. The bike was locked in a straight upright position on a lift table. I think being able to tilt the bike so the "dead zone" was lower than the outlets may have prevented air from collecting there. Or, I could be full of it. Your opinion?
BTW, I was tapping with a wrench on the MC and calipers during the bleeding process to help dislodge bubbles. Waste of time?
Thanks again.
