TOPIC: 650 SR 1981 (z750L engine)
650 SR 1981 (z750L engine) 29 Jan 2018 11:58 #777984
  • gordone
  • gordone's Avatar Topic Author
  • Thank you received: 47
Today have I mounted the front fork to the frame and installed new roller bearings for the steering.
I hope I have torqued the bolt for the steering correct, not to much or less....
So fun to building the bike and not only take a part :)
Project:
650 SR 1981 (z750L engine) 30 Jan 2018 11:34 #778022
  • gordone
Today have I installed the main? stand, front wheel and the steering, have attached some photos.
The steering is not 100% streight, it was not 100% before either. When I release the bolts for the upper and lower part who clamp on the upper fork I can adjust so the steering is streight, but when I torque up the bolts again it drags some back... it`s not much... but some....
I think I will leave it for now... I properly need to replace the upper or lower part..... ?
I have also added 248cc oil to the front fork, I was not sure what capacity I have since the forks has been rebuild with different parts, but 248cc is according to 80-81 KZ750-E (USA).
Project:
Last edit: by gordone.
650 SR 1981 (z750L engine) 10 Feb 2018 04:58 #778455
  • gordone
I have now rebuild all three brake calipers, have attached some photos.
I have now started to install the electrical system on the bike again. I will reuse existing for now,
but the plan is to build new next winter.
Project:
650 SR 1981 (z750L engine) 13 Feb 2018 10:16 #778689
  • gordone
Today have I installed the new Hagon rear suspension, have attached some photos.
Project:
650 SR 1981 (z750L engine) 13 Feb 2018 10:31 #778691
  • Bdog
  • Bdog's Avatar
  • Member
  • Member
  • Sweep the leg johnny!!!
  • Thank you received: 6
Wow, it looks really good. Great progress!
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
650 SR 1981 (z750L engine) 13 Feb 2018 11:21 #778695
  • ajsfirehawk
  • ajsfirehawk's Avatar
  • Thank you received: 89
Hagon shocks changed the personality and handling of my 650 D2 more than any other change I've made. Progressive springs, new seals and fluid in the forks was good, but the shocks were huge.
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
06 ZG1000 Concours
02 Trans Am ... not enough time
650 SR 1981 (z750L engine) 13 Feb 2018 22:40 #778731
  • gordone
ajsfirehawk wrote: Hagon shocks changed the personality and handling of my 650 D2 more than any other change I've made. Progressive springs, new seals and fluid in the forks was good, but the shocks were huge.
Looking forward to test the bike again :)
I was thinking the rear suspension was less important then front, but rear is maybe important for my ass :) hehe?
Project:
650 SR 1981 (z750L engine) 16 Feb 2018 08:16 #778861
  • gordone
Last work I have done is to pimp up the gauges for rpm and speed... It was some corrosion etc.... I have not done a 100% overhaul, since my plan is to rebuild everything when it comes to electricity and switches gauges etc.. next winter.
I have also reinstalled the left and right switches, have been able to locate a new plastic knop for the right side.
I have also received the top back, workshop have tapped of some on the inlet valves, so I can manage to get correct valve clearness.
I`m waiting for the last part before I can install the oil pan again and start to reinstall the engine.
I did not find any good picture before I started to overhaul the gauges:
After:
Project:
650 SR 1981 (z750L engine) 19 Feb 2018 10:05 #778993
  • gordone
Today have I rebuild the brake cylinder rear with new parts, ready to be installed when I receive the rest of the parts (brake lines etc).
Tomorrow is the plan to rebuild the underside of the engine, install the oil pan again, will pick up the last part tomorrow.
Project:
650 SR 1981 (z750L engine) 21 Feb 2018 12:07 #779121
  • gordone
Today have I installed the oil pan again. I have also washed the cylinders with mineral oil, the cylinder has a fresh borr and hone job, I shall install 810 big bore kit.
Plan further is to rebuild the whole engine and then paint the engine and store it for some months, while building the rest and then install it into the frame, do the last pices and start it up and do the burn in procedure.
Murphy's law will properly come hehe, but I try to do everything correct the first time.
I want to thank you all members on these form for your input and help, without you I will had big problem doing rebuild of the bike, so thank you.
Project:
650 SR 1981 (z750L engine) 22 Feb 2018 11:21 #779189
  • gordone
Today have I installed the pistons, will continue on Saturday.
Project:
650 SR 1981 (z750L engine) 24 Feb 2018 14:00 #779290
  • gordone
Today have I continue with the engine rebuild. I have installed the block and the top. I have only been able to torque up to 20Nm, my torque wrench is not going higher, will get a larger one on Monday and torque up to final 40Nm according to the service manual.
I used threebond sealer on four locations according to the service manual and then sprayed the whole gasket with copper spray.
Cross my fingers for now oil leak :)
Plan for tomorrow is to check valve clearness and install the cams and the timing chain.
Project:
