82 KZ1000 LTD refresh.
- zukdave
12 Mar 2017 07:15
My buddy Dan brought me his LTD thats been in his living room for the last two years to clean up and put back together for him.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: DSummerlin
- zukdave
Re: 82 KZ1000 LTD refresh.
12 Mar 2017 07:17
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
12 Mar 2017 07:25 - 12 Mar 2017 07:27
Dan had split the case to replace the shift drum and had one bolt break so I try'd doing te weld a nut to trick
but couldn't get enough heat in it to free it so had to drill and then Heli-coil it.
I think for having 48,000 mile's the trans looks great.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 12 Mar 2017 07:27 by zukdave.
- zukdave
12 Mar 2017 16:08
This morning got the frame all wire brushed and sprayed with rust converter.
That stuff looks like clear coat when you spray it on.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- mopguy
12 Mar 2017 16:35
I found Tremclad Rust paint in semigloss available at Home Depot a very close match for touching up the frame.
The following user(s) said Thank You: GPz550D1, kz550oak
- zukdave
12 Mar 2017 16:37
By time I got that done Dan came over and we got the bolt issue taken care of and the case's back together.
Still need to torque everything but it's in one piece now. over look the shop I'm still moving in.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
13 Mar 2017 20:18
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
13 Mar 2017 20:34
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
14 Mar 2017 06:28
sweet !
can't wait to see how it turns out.
The following user(s) said Thank You: GPz550D1, DSummerlin
- DSummerlin
14 Mar 2017 08:12
That's my bike and I'm really happy to have Dave pushing to get it together. He doesn't mess around and I trust him to help me get it done right. He's not letting me cut any corners so I think it's gonna be way cleaner than I had planned. I'm not complaining.
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
82 KZ1000 LTD
99 ZRX 1100
- zukdave
14 Mar 2017 09:18
Thanks Dan .
Plan for tonight is get the motor finish cleaned and some paint on it and another coat on the frame.
Thinking we should be able to get the motor in Thursday and fire it up Sat.or Sunday.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
16 Mar 2017 19:24
Last night got the motor cleaned up and painted.
Tonight I got the finish coat of paint on the frame it'll need to sit a few days before we put the motor
so time to clean and paint the small parts.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
