New rebuild after 10 years "deep sleep" mode 11 Jul 2017 17:26 #766720
  • Scirocco
  • Scirocco's Avatar Topic Author
  • Premium Member
  • Thank you received: 1895
Yes, you are right and it will be looking better with new race flag decals and tank emblems on.
I need self adhesive emblems because i had removed the screw mounting strip and filled the recess
with tin and a soldering iron and tin plated the tank opening area for rust protection !!!
New rebuild after 10 years "deep sleep" mode 14 Jul 2017 16:22 #766952
  • Scirocco
  • Premium Member
Did some little cosmetics on my Marving Race muffler.
Take some piece aluminum out of an damaged hydraulic rotary distributor.
Do some 7 mm holes in it.
after 30 minutes on the lathe
New rebuild after 10 years "deep sleep" mode 14 Jul 2017 16:29 #766953
  • Scirocco
  • Premium Member
Press in the silencer pipe
Press in to the silencer
Have to do one bore and screw to hold it in and two rivets for the model number plate.
Made it self and save some money ( 50 Euros )
Looking good ???
Last edit: by Scirocco.
New rebuild after 10 years "deep sleep" mode 16 Jul 2017 16:02 #767113
  • Scirocco
  • Premium Member
A small update.
Take some time on the holy Sunday and install my speed sensor of my new KOSO speedo.
Have to hurry up my project,will try to drive street legal this month.
MVI_1942.mov
    MVI_1942.mov
New rebuild after 10 years "deep sleep" mode 03 Aug 2017 16:56 #768276
  • Scirocco
  • Premium Member
A quick update of my delay progress.
Buy some tank emblems to tape on.
a new set of handle bar switches
Have to buy a new main wiring harness, the old one was a totally connector patchwork by the PO,
Plus a set of new throttle cables.
A new clear glass headlight
New rebuild after 10 years "deep sleep" mode 03 Aug 2017 17:02 #768279
  • Scirocco
  • Premium Member
Made some brackets for my KOSO speedo and the ignition switch mod.
New rebuild after 10 years "deep sleep" mode 03 Aug 2017 17:10 #768280
  • Scirocco
  • Premium Member
KOSO mounted and ready for the adjustments.
New rebuild after 10 years "deep sleep" mode 03 Aug 2017 17:16 #768281
  • Scirocco
  • Premium Member
Turn signals on handle bar are missing, coming on Saturday
The following user(s) said Thank You: GPz550D1, gordone
New rebuild after 10 years "deep sleep" mode 04 Aug 2017 06:58 #768297
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
Looking good, keep up that great work that you do.
New rebuild after 10 years "deep sleep" mode 09 Jan 2018 23:55 #777138
  • Scirocco
  • Premium Member
First photo update in 2018, more will come.....
New rebuild after 10 years "deep sleep" mode 11 Jan 2018 00:37 #777187
  • Scirocco
  • Premium Member
Made some bracket for the weekend man cave, cam timing need some work.
More pics will follow...
New rebuild after 10 years "deep sleep" mode 11 Jan 2018 14:07 #777205
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
I just caught up with this thread. nice work on that muffler tip!
