- Thank you received: 2811
Retroactive KZ750E Project Thread
13 Jan 2017 10:23 - 04 Aug 2017 07:47 #752092
by Nessism
Replied by Nessism on topic Retroactive KZ750E Project Thread
Put new wires in the coils. Was able to pull the exterior protective shield tubing off the old wires and install them on the new wires. Installed new plug caps too. Went with NGK's from Z1. Not OEM but that's okay for this project.
Last edit: 04 Aug 2017 07:47 by Nessism.
The following user(s) said Thank You: Mir
13 Jan 2017 10:26 - 04 Aug 2017 07:53 #752093
by Nessism
Rolling chassis...
[img]https://farm5.staticflickr.com/4292/35441854834_563af4f84b_b.jpg[/img [img]https://farm5.staticflickr.com/4300/35469902153_ff7d27861a_b.jpg[/img]
Last edit: 04 Aug 2017 07:53 by Nessism.
13 Jan 2017 10:27 - 04 Aug 2017 07:55 #752094
by Nessism
Last edit: 04 Aug 2017 07:55 by Nessism.
13 Jan 2017 10:29 - 04 Aug 2017 07:57 #752095
by Nessism
Put the brake lines together today. Earl's Speed-Seal. Took some photos in anticipation of making a tutorial. We all know how much everyone likes photos around here...
Old lines...
New Earl's parts...
Tools...
Old lines...
New Earl's parts...
Tools...
Last edit: 04 Aug 2017 07:57 by Nessism.
13 Jan 2017 10:32 - 04 Aug 2017 08:47 #752096
by Nessism
Last edit: 04 Aug 2017 08:47 by Nessism.
13 Jan 2017 10:34 - 04 Aug 2017 08:49 #752097
by Nessism
Look down inside the ferrule and make sure the inner teflon liner is fully seated down to the step inside the ferrule.
Shove the hose on firmly while tightening the nut. Tighten almost all the way, but stop just short so the hose end can be clocked with the other.
Last edit: 04 Aug 2017 08:49 by Nessism.
13 Jan 2017 10:35 - 04 Aug 2017 08:51 #752098
by Nessism
Last edit: 04 Aug 2017 08:51 by Nessism.
13 Jan 2017 10:36 - 04 Aug 2017 08:57 #752100
by Nessism
Whack the chisel with the mini sledge...
Check clocking of the hose ends by pressing one on the table and looking at the other. On this hose they are 90 degrees from each other.
Install the other hose end, clock the position carefully, and you are done. I used non adjustable hose ends but they work out fine. You just need to be careful to stop a little short of fully tight so you can get the clocking right.
Repeat everything three more times and...
Some heat shrink tubing can be used to cover up where the vinyl coating was removed. Next time...
Last edit: 04 Aug 2017 08:57 by Nessism.
13 Jan 2017 10:39 - 04 Aug 2017 08:59 #752101
by Nessism
Cleaned up the harness best I could and re-wrapped it with Elliott Tape EE 201 non adhesive tape. Good stuff. The 201 flavor is the high temp stuff so heat shouldn't be an issue. Non adhesive like the stock harness wrap so the harness doesn't turn into a sticky mess.
Used a combination of Deoxit, Scotchbrite, stainless steel wire brush, and a dremel tool to clean corrosion off the electrical contacts. Pinched closed the female terminals where ever possible.
Bought some new electrical terminals and crimping pliers from Vintage Connection. These things roll over the edges over on the terminals just like the OEM terminals. They seem more secure than the smash flat terminals that are so common these days.
Snuck in a SH-775 R/R under the battery box. Had to make a bracket first but it turned out pretty well.
[/url]
[/url]
Last edit: 04 Aug 2017 08:59 by Nessism.
13 Jan 2017 10:41 - 04 Aug 2017 09:03 #752102
by Nessism
Chassis electrical is all hooked up and working. Installed GPz style turn signals, K&S brand. They look good but are pretty junky on the inside (cheap electrical socket).
Last edit: 04 Aug 2017 09:03 by Nessism.
13 Jan 2017 10:43 - 04 Aug 2017 09:04 #752103
by Nessism
Last edit: 04 Aug 2017 09:04 by Nessism.
13 Jan 2017 10:48 - 04 Aug 2017 09:06 #752104
by Nessism
Painted up the seat pan and installed a Pit Replica seat cover. The cover itself is an excellent visual reproduction of the 1981 750E pattern. Unfortunately, the lower flange area is poorly executed and is easy to tear. I wound up having to get a second cover and was more careful during install the second time around...
Last edit: 04 Aug 2017 09:06 by Nessism.
